Jion Active Directory
Could not connect to AD Server ucs.bluezebra.intra. Please verify that username and password are correct. (Details:
well-known-sid-object-rename failed with 1 (kdestroy: krb5_cc_destroy: Did not find a plugin for ccache_ops
kinit: krb5_get_init_creds: Client (admin@BLUEZEBRA.INTRA) unknown
File “/usr/share/univention-ad-connector/scripts/well-known-sid-object-rename”, line 400, in
ad = Well_Known_SID_object_renamer(ucr, options.binddn, options.bindpwd)
File “/usr/share/univention-ad-connector/scripts/well-known-sid-object-rename”, line 81, in init
self.ad_connect()
File “/usr/share/univention-ad-connector/scripts/well-known-sid-object-rename”, line 147, in ad_connect
self.ucr[’%s/ad/ldap/certificate’ % CONFIGBASENAME]
File “/usr/lib/pymodules/python2.7/univention/connector/ad/init.py”, line 806, in init
self.lo.sasl_interactive_bind_s("", auth)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 962, in sasl_interactive_bind_s
res = self._apply_method_s(SimpleLDAPObject.sasl_interactive_bind_s,*args,**kwargs)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 931, in _apply_method_s
return func(self,*args,**kwargs)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 244, in sasl_interactive_bind_s
return self._ldap_call(self._l.sasl_interactive_bind_s,who,auth,RequestControlTuples(serverctrls),RequestControlTuples(clientctrls),sasl_flags)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 106, in _ldap_call
result = func(*args,**kwargs)
ldap.LOCAL_ERROR: {‘info’: ‘SASL(-1): generic failure: GSSAPI Error: Unspecified GSS failure. Minor code may provide more information (No Kerberos credentials available (default cache: /var/cache/univention-ad-connector/krb5.cc.well))’, ‘desc’: ‘Local error’}
