Issues with Office 365 Connector in UCS SSO Deployment
Hi everyone,
We are experiencing problems with the Office 365 / Microsoft 365 connector while setting up UCS SSO with Keycloak. The main issues observed:
  1. SAML Setup Script Fails
  • saml_setup.bat fails on both PowerShell 5.x and 7.x.
  • Errors include Command not recognized for Set-MgDomainAuthentication and Connect-MgGraph.
  • Interactive authentication using WAM complicates automated execution.
  1. Domain / LDAP Instability
  • User import scripts sometimes lock slapd or leave LDAP in an inconsistent state.
  • Attempts to update IdP metadata or sync users fail intermittently.
  1. Keycloak Container Issues
  • H2 database locking (keycloakdb.mv.db) prevents startup in dev mode.
  • Incorrect volume permissions and port conflicts can cause crashes, leaving Apache endpoints without a backend.
Impact:
  • Office 365 connector cannot complete synchronization.
  • SAML endpoints for the UCS realm are unavailable (404 Realm does not exist or 503 Service Unavailable).
  • Manual remediation is required for both Keycloak and the domain before attempting connector operations again.
Commands and Context:
  • PowerShell (attempts on Windows):
Connect-MgGraph -Scopes Domain.ReadWrite.All, Directory.ReadWrite.All
Set-MgDomainAuthentication -DomainName example.com -Authentication ...
  • Keycloak Docker attempts on UCS VM:
docker run --rm -v /opt/keycloak/data:/opt/keycloak/data \
  -v /usr/local:/host docker.software-univention.de/keycloak-keycloak:26.4.7-ucs1 \
  start-dev --hostname sso.example.com --http-enabled true
  export --realm=ucs --file=/host/ucs-realm.json
Request:
Has anyone successfully run the Office 365 connector with UCS SSO recently? Any guidance on:
  • PowerShell non-interactive execution of saml_setup.bat
  • Fixing H2 DB locking or Keycloak dev mode issues
  • Reliable Office 365 connector synchronization
Thanks in advance for your advice!
