Is UCS better then FreeIPA?
Hello ,
I have like 20 Linux virtual machines and some Cisco routers I want to ask Can I use UCS as a centralized authentication for my Linux and Cisco machines ?
I mean instead of using SSH login each time ? and is it better FreeIPA ?
Notice = I’m using 80% Debian
Best Regards
UCS is debian based. And yes UCS uses LDAP and Radius. I do network auth here for Cisco and HP.
Can I ask you what are you doing on UCS to reach Cisco devices ? what did you configure exactly on the Cisco devices and UCS ?
Yes you can.
install freeradius and configure it with your equipment!
When installing freeradius it automatically runs the LDAP-based authentication service
Yes, we already have an app for that: RADIUS - Univention App Center
With this, you can authenticate your users via RADIUS against the LDAP. Network access can be configured per user or group. Then you just have to configure your UCS system as your RADIUS server in the cisco switches.
