Is it possible for owncloud on UCs to have more upload than 2mb?
Have tried multiple times on UCS 5 and owncloud 10.7 - IS IT A BUG? CANNOT change upload file sizes even in univention-app shell owncloud with vin /var/www/owncloud/config.php
PHP changes have no effect. Have changed in apache2 php as well - I have changed 5-6 different php files and nothing changes the upload limit - any help appreciated.
Look inside owncloud-docker for /etc/php/< versionnumber >/cli/php.ini
There you will find the entry:
upload_max_filesize = 2M
But it is very strange, that this limitation is active agan. It is longer than 5 years ago, that owncloud needed a change there.
Thank you - using Winscp it didnt show a php 7.4 folder, only a 7.0 and 7.3 - I did find a file there from the CLI and within owncloud docker - and made the change but it is still holding me to the 2m upload limit - if I download the config file from within owncloud, it shows the file change but still cant upload larger than 2 mb! So puzzling! yes it ran fine for years but after the change to UCS 5 we had to reinstall - it seemed to find most of the old settings, but this one will not change! It was previously set to allow up to 2GB
Thanks for your help. Basically I get an orange Abort button and nothing happens - no warning or notification about file sizes.
In earlier days there were several php.ini files. Maybe there are more than one php.ini in the container f.ex. in /etc/php/< version >/apache2/php.ini.
I think you are absolutely right - is there a command you know of to show all the php libraries? It is showing php 7.4, but I only have php 7.0 and 7.3 installed in Univention. If I vim to find the php 7.3 ini in univention-app shell owncloud it shows a blank page, with no ini. I am afraid to create a new one as I am not sure of the result! Thank you for you input
I did a
find -name php.ini
within the docker.
If “vim” does not exist do a
apt-get install vim
to edit the php.ini.
Awesome thank you! it gives me an empty return on that although I was able to see and change a php.ini from php 7.4 within the owncloud docker, but it didnt make any changes
Do the find-instruction in the root directory.
Awesome! Worked - it shows the 2 files I have modified, but at least it closes the door on that - image
        "Vendor Name": "OpenLDAP",
        "Vendor Version": "20449",
        "SASL Support": "Enabled",
        "ldap.max_links": "Unlimited"
    "libsmbclient": {
        "Version": "1.0.6"
    "libxml": {
        "libXML support": "active",
        "libXML Compiled Version": "2.9.10",
        "libXML Loaded Version": "20910",
        "libXML streams": "enabled"
    "mbstring": {
        "Multibyte Support": "enabled",
        "Multibyte string engine": "libmbfl",
        "HTTP input encoding translation": "disabled",
        "libmbfl version": "1.3.2",
        "Multibyte (japanese) regex support": "enabled",
        "Multibyte regex (oniguruma) version": "6.9.4",
        "mbstring.detect_order": "no value",
        "mbstring.encoding_translation": "Off",
        "mbstring.func_overload": "0",
        "mbstring.http_input": "no value",
        "mbstring.http_output": "no value",
        "mbstring.http_output_conv_mimetypes": "^(text\/|application\/xhtml\\+xml)",
        "mbstring.internal_encoding": "no value",
        "mbstring.language": "neutral",
        "mbstring.regex_retry_limit": "1000000",
        "mbstring.regex_stack_limit": "100000",
        "mbstring.strict_detection": "Off",
        "mbstring.substitute_character": "no value"
    "mysqli": {
        "Client API library version": "mysqlnd 7.4.3",
        "Active Persistent Links": "0",
        "Inactive Persistent Links": "0",
        "Active Links": "0",
        "mysqli.allow_local_infile": "Off",
        "mysqli.allow_persistent": "On",
        "mysqli.default_host": "no value",
        "mysqli.default_port": "3306",
        "mysqli.default_pw": "no value",
        "mysqli.default_socket": "no value",
        "mysqli.default_user": "no value",
        "mysqli.max_links": "Unlimited",
        "mysqli.max_persistent": "Unlimited",
        "mysqli.reconnect": "Off",
        "mysqli.rollback_on_cached_plink": "Off"
    "mysqlnd": {
        "Version": "mysqlnd 7.4.3",
        "Compression": "supported",
        "core SSL": "supported",
        "extended SSL": "supported",
        "Command buffer size": "4096",
        "Read buffer size": "32768",
        "Read timeout": "86400",
        "Collecting statistics": "Yes",
        "Collecting memory statistics": "No",
        "Tracing": "n\/a",
        "Loaded plugins": "mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_caching_sha2_password,auth_plugin_sha256_password",
        "API Extensions": "mysqli,pdo_mysql"
    "openssl": {
        "OpenSSL support": "enabled",
        "OpenSSL Library Version": "OpenSSL 1.1.1f 31 Mar 2020",
        "OpenSSL Header Version": "OpenSSL 1.1.1f 31 Mar 2020",
        "Openssl default config": "\/usr\/lib\/ssl\/openssl.cnf",
        "openssl.cafile": "no value",
        "openssl.capath": "no value"
    "pcre": {
        "PCRE (Perl Compatible Regular Expressions) Support": "enabled",
        "PCRE Library Version": "10.34 2019-11-21",
        "PCRE Unicode Version": "12.1.0",
        "PCRE JIT Support": "enabled",
        "PCRE JIT Target": "x86 64bit (little endian + unaligned)",
        "pcre.backtrack_limit": "1000000",
        "pcre.jit": "1",
        "pcre.recursion_limit": "100000"
    "PDO": {
        "PDO drivers": "mysql, pgsql, sqlite"
    "pdo_mysql": {
        "Client API version": "mysqlnd 7.4.3",
        "pdo_mysql.default_socket": "\/var\/run\/mysqld\/mysqld.sock"
    "pdo_pgsql": {
        "PDO Driver for PostgreSQL": "enabled",
        "PostgreSQL(libpq) Version": "12.4 (Ubuntu 12.4-0ubuntu0.20.04.1)"
    "pdo_sqlite": {
        "SQLite Library": "3.31.1"
    "pgsql": {
        "PostgreSQL(libpq) Version": "12.4 (Ubuntu 12.4-0ubuntu0.20.04.1)",
        "PostgreSQL(libpq)": "PostgreSQL 12.4 (Ubuntu 12.4-0ubuntu0.20.04.1) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 9.3.0-10ubuntu2) 9.3.0, 64-bit",
        "Multibyte character support": "enabled",
        "SSL support": "enabled",
        "pgsql.allow_persistent": "On",
        "pgsql.auto_reset_persistent": "Off",
        "pgsql.ignore_notice": "Off",
        "pgsql.log_notice": "Off",
        "pgsql.max_links": "Unlimited",
        "pgsql.max_persistent": "Unlimited"
    "Phar": {
        "Phar API version": "1.1.1",
        "Phar-based phar archives": "enabled",
        "Tar-based phar archives": "enabled",
        "ZIP-based phar archives": "enabled",
        "gzip compression": "enabled",
        "bzip2 compression": "disabled (install ext\/bz2)",
        "Native OpenSSL support": "enabled",
        "Phar based on pear\/PHP_Archive, original concept by Davey Shafik.Phar fully realized by Gregory Beaver and Marcus Boerger.Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.": null,
        "phar.cache_list": "no value",
        "phar.readonly": "On",
        "phar.require_hash": "On"
    "posix": {
        "POSIX support": "enabled"
    "readline": {
        "Readline library": "EditLine wrapper",
        "cli.pager": "no value",
        "cli.prompt": "\\b \\&gt; "
    "redis": {
        "Redis Version": "5.1.1",
        "Available serializers": "php, json, igbinary",
        "redis.arrays.algorithm": "no value",
        "redis.arrays.auth": "no value",
        "redis.arrays.autorehash": "0",
        "redis.arrays.connecttimeout": "0",
        "redis.arrays.consistent": "0",
        "redis.arrays.distributor": "no value",
        "redis.arrays.functions": "no value",
        "redis.arrays.hosts": "no value",
        "redis.arrays.index": "0",
        "redis.arrays.lazyconnect": "0",
        "redis.arrays.names": "no value",
        "redis.arrays.pconnect": "0",
        "redis.arrays.previous": "no value",
        "redis.arrays.readtimeout": "0",
        "redis.arrays.retryinterval": "0",
        "redis.clusters.auth": "no value",
        "redis.clusters.cache_slots": "0",
        "redis.clusters.persistent": "0",
        "redis.clusters.read_timeout": "0",
        "redis.clusters.seeds": "no value",
        "redis.clusters.timeout": "0",
        "redis.pconnect.connection_limit": "0",
        "redis.pconnect.pooling_enabled": "1",
        "redis.session.lock_expire": "0",
        "redis.session.lock_retries": "10",
        "redis.session.lock_wait_time": "2000",
        "redis.session.locking_enabled": "0"
    "Reflection": {
        "Reflection": "enabled"
    "session": {
        "Session Support": "enabled",
        "Registered save handlers": "files user redis rediscluster",
        "Registered serializer handlers": "php_serialize php php_binary igbinary",
        "session.auto_start": "Off",
        "session.cache_expire": "180",
        "session.cache_limiter": "nocache",
        "session.cookie_domain": "no value",
        "session.cookie_httponly": [
            "1",
            "no value"
        "session.cookie_lifetime": "0",
        "session.cookie_path": [
            "\/owncloud",
        "session.cookie_samesite": [
            "Strict",
            "no value"
        "session.cookie_secure": [
            "1",
            "0"
        "session.gc_divisor": "1000",
        "session.gc_maxlifetime": [
            "1200",
            "1440"
        "session.gc_probability": "0",
        "session.lazy_write": "On",
        "session.name": [
            "oco5gx65c3he",
            "PHPSESSID"
        "session.referer_check": "no value",
        "session.save_handler": "files",
        "session.save_path": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/sessions",
        "session.serialize_handler": "php",
        "session.sid_bits_per_character": "5",
        "session.sid_length": "26",
        "session.upload_progress.cleanup": "On",
        "session.upload_progress.enabled": "On",
        "session.upload_progress.freq": "1%",
        "session.upload_progress.min_freq": "1",
        "session.upload_progress.name": "PHP_SESSION_UPLOAD_PROGRESS",
        "session.upload_progress.prefix": "upload_progress_",
        "session.use_cookies": "1",
        "session.use_only_cookies": "1",
        "session.use_strict_mode": "0",
        "session.use_trans_sid": "0"
    "shmop": {
        "shmop support": "enabled"
    "SimpleXML": {
        "SimpleXML support": "enabled",
        "Schema support": "enabled"
    "smbclient": {
        "smbclient Support": "enabled",
        "smbclient extension Version": "1.0.6",
        "libsmbclient library Version": "4.11.6-Ubuntu"
    "soap": {
        "Soap Client": "enabled",
        "Soap Server": "enabled",
        "soap.wsdl_cache": "1",
        "soap.wsdl_cache_dir": "\/tmp",
        "soap.wsdl_cache_enabled": "1",
        "soap.wsdl_cache_limit": "5",
        "soap.wsdl_cache_ttl": "86400"
    "sockets": {
        "Sockets Support": "enabled"
    "sodium": {
        "libsodium headers version": "1.0.18",
        "libsodium library version": "1.0.18"
    "SPL": {
        "Interfaces": "OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject",
        "Classes": "AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException"
    "sqlite3": {
        "SQLite Library": "3.31.1",
        "sqlite3.defensive": "1",
        "sqlite3.extension_dir": "no value"
    "standard": {
        "Dynamic Library Support": "enabled",
        "Path to sendmail": "\/usr\/sbin\/sendmail -t -i",
        "assert.active": "1",
        "assert.bail": "0",
        "assert.callback": "no value",
        "assert.exception": "0",
        "assert.quiet_eval": "0",
        "assert.warning": "1",
        "auto_detect_line_endings": "0",
        "default_socket_timeout": "60",
        "from": "no value",
        "session.trans_sid_hosts": "no value",
        "session.trans_sid_tags": "a=href,area=href,frame=src,form=",
        "unserialize_max_depth": "4096",
        "url_rewriter.hosts": "no value",
        "url_rewriter.tags": "form=",
        "user_agent": "no value"
    "sysvmsg": {
        "sysvmsg support": "enabled"
    "sysvsem": {
        "sysvsem support": "enabled"
    "sysvshm": {
        "sysvshm support": "enabled"
    "tokenizer": {
        "Tokenizer Support": "enabled"
    "xml": {
        "XML Support": "active",
        "XML Namespace Support": "active",
        "libxml2 Version": "2.9.10"
    "xmlreader": {
        "XMLReader": "enabled"
    "xmlwriter": {
        "XMLWriter": "enabled"
    "xsl": {
        "XSL": "enabled",
        "libxslt Version": "1.1.34",
        "libxslt compiled against libxml Version": "2.9.10",
        "EXSLT": "enabled",
        "libexslt Version": "1.1.34"
    "Zend OPcache": {
        "Opcode Caching": "Up and Running",
        "Optimization": "Enabled",
        "SHM Cache": "Enabled",
        "File Cache": "Disabled",
        "Startup": "OK",
        "Shared memory model": "mmap",
        "Cache hits": "234968",
        "Cache misses": "1175",
        "Used memory": "28456000",
        "Free memory": "105761728",
        "Wasted memory": "0",
        "Interned Strings Used memory": "6290008",
        "Interned Strings Free memory": "1000",
        "Cached scripts": "1147",
        "Cached keys": "2195",
        "Max keys": "16229",
        "OOM restarts": "0",
        "Hash keys restarts": "0",
        "Manual restarts": "0",
        "opcache.blacklist_filename": "no value",
        "opcache.consistency_checks": "0",
        "opcache.dups_fix": "Off",
        "opcache.enable": "On",
        "opcache.enable_cli": "Off",
        "opcache.enable_file_override": "Off",
        "opcache.error_log": "no value",
        "opcache.file_cache": "no value",
        "opcache.file_cache_consistency_checks": "1",
        "opcache.file_cache_only": "0",
        "opcache.file_update_protection": "2",
        "opcache.force_restart_timeout": "180",
        "opcache.huge_code_pages": "Off",
        "opcache.interned_strings_buffer": "8",
        "opcache.lockfile_path": "\/tmp",
        "opcache.log_verbosity_level": "1",
        "opcache.max_accelerated_files": "10000",
        "opcache.max_file_size": "0",
        "opcache.max_wasted_percentage": "5",
        "opcache.memory_consumption": "128",
        "opcache.opt_debug_level": "0",
        "opcache.optimization_level": "0x7FFEBFFF",
        "opcache.preferred_memory_model": "no value",
        "opcache.preload": "no value",
        "opcache.preload_user": "no value",
        "opcache.protect_memory": "0",
        "opcache.restrict_api": "no value",
        "opcache.revalidate_freq": "2",
        "opcache.revalidate_path": "Off",
        "opcache.save_comments": "1",
        "opcache.use_cwd": "On",
        "opcache.validate_permission": "Off",
        "opcache.validate_root": "Off",
        "opcache.validate_timestamps": "On"
    "zip": {
        "Zip": "enabled",
        "Zip version": "1.15.6",
        "Libzip headers version": "1.5.1",
        "Libzip library version": "1.5.1"
    "zlib": {
        "Stream Wrapper": "compress.zlib:\/\/",
        "Stream Filter": "zlib.inflate, zlib.deflate",
        "Compiled Version": "1.2.11",
        "Linked Version": "1.2.11",
        "zlib.output_compression": "Off",
        "zlib.output_compression_level": "-1",
        "zlib.output_handler": "no value"
    "Environment": {
        "OPENID_LOGIN_ENABLED": "false",
        "OWNCLOUD_DOMAIN": "bldomain.com",
        "SU_EXEC_CHECKSUM": "0f25a21cf64e58078057adc78f38705163c1d564a959ff30a891c31917011a54",
        "OWNCLOUD_MAX_EXECUTION_TIME": "3600",
        "OWNCLOUD_ALLOW_USER_TO_CHANGE_DISPLAY_NAME": "no value",
        "OWNCLOUD_ADMIN_USERNAME": "owncloud",
        "OWNCLOUD_DB_NAME": "owncloud",
        "OWNCLOUD_MAIL_SMTP_SECURE": "no value",
        "REDIS_PORT": "tcp:\/\/172.17.0.1:6379",
        "OWNCLOUD_OBJECTSTORE_BUCKET": "owncloud",
        "APACHE_SERVER_SIGNATURE": "Off",
        "OWNCLOUD_SHARE_FOLDER": "no value",
        "OWNCLOUD_SYNC_DISABLE_MODE": "disable",
        "OWNCLOUD_PREVIEW_OFFICE_CL_PARAMETERS": "no value",
        "OWNCLOUD_COMMENTS_MANAGER_FACTORY": "no value",
        "OWNCLOUD_PROXY_USERPWD": "no value",
        "OWNCLOUD_CIPHER": "no value",
        "REDIS_PORT_6379_TCP_ADDR": "172.17.0.1",
        "REDIS_1_PORT_6379_TCP": "tcp:\/\/172.17.0.1:6379",
        "nameserver1": "192.168.2.79",
        "HOSTNAME": "f2d3a628c257",
        "OWNCLOUD_FILELOCKING_TTL": "no value",
        "REDIS_ENV_TERM": "xterm",
        "OWNCLOUD_REDIS_PORT": "6379",
        "REDIS_NAME": "\/owncloud_owncloud_1\/redis",
        "nameserver2": "192.168.2.201",
        "APACHE_HOSTNAME_LOOKUPS": "Off",
        "OWNCLOUD_MYSQL_UTF8MB4": "true",
        "OWNCLOUD_POST_CRONJOB_PATH": "\/etc\/post_cronjob.d",
        "APACHE_DOCUMENT_ROOT": "\/var\/www\/owncloud",
        "OWNCLOUD_VOLUME_CERTS": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/certs",
        "OWNCLOUD_ENABLE_PREVIEWS": "no value",
        "SHLVL": "0",
        "nameserver3": "192.168.2.100",
        "OWNCLOUD_SESSION_SAVE_PATH": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/sessions",
        "OWNCLOUD_REDIS_1_PORT_6379_TCP": "tcp:\/\/172.17.0.1:6379",
        "ldap_master": "ucs-bdc.bldomain.com",
        "HOME": "\/root",
        "APACHE_ERROR_LOG": "\/dev\/stderr",
        "REDIS_PORT_6379_TCP_PORT": "6379",
        "OWNCLOUD_VOLUME_APPS": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/custom",
        "OPENID_SEARCH_CLAIM": "email",
        "OWNCLOUD_SESSION_KEEPALIVE": "no value",
        "OWNCLOUD_DEFAULT_APP": "no value",
        "OWNCLOUD_ENABLED_PREVIEW_PROVIDERS": "no value",
        "OWNCLOUD_DB_USERNAME": "owncloud",
        "OWNCLOUD_OBJECTSTORE_CLASS": "OCA\\ObjectStore\\S3",
        "OWNCLOUD_OBJECTSTORE_ENABLED": "false",
        "APACHE_ACCESS_LOG": "\/dev\/stdout",
        "REDIS_PORT_6379_TCP_PROTO": "tcp",
        "OWNCLOUD_OBJECTSTORE_REGION": "us-east-1",
        "OWNCLOUD_SHARING_FEDERATION_ALLOW_HTTP_FALLBACK": "no value",
        "OWNCLOUD_OBJECTSTORE_ENDPOINT": "s3-us-east-1.amazonaws.com",
        "OWNCLOUD_MAIL_SMTP_AUTH": "no value",
        "OWNCLOUD_REDIS_SESSION_LOCK_RETRIES": "750",
        "OWNCLOUD_CACHE_CHUNK_GC_TTL": "no value",
        "ldap_master_port": "7389",
        "OWNCLOUD_REDIS_DB": "no value",
        "UPDATE_WARNING_RELEASENOTES": "no",
        "APACHE_KEEP_ALIVE": "On",
        "GOMPLATE_CHECKSUM": "7dbabe30095f822ec38f5f70711ff121c26e588227da4cc05208417cfaf929cd",
        "OWNCLOUD_MAIL_FROM_ADDRESS": "no value",
        "OWNCLOUD_TOKEN_AUTH_ENFORCED": "no value",
        "OWNCLOUD_UPGRADE_AUTOMATIC_APP_UPDATES": "no value",
        "OWNCLOUD_BLACKLISTED_FILES": "no value",
        "OWNCLOUD_OBJECTSTORE_SECRET": "no value",
        "docker_host_name": "ucs-bdc.bldomain.com",
        "OWNCLOUD_KNOWLEDGEBASE_ENABLED": "no value",
        "OWNCLOUD_INTEGRITY_EXCLUDED_FILES": "no value",
        "OWNCLOUD_LOGIN_ALTERNATIVES": "no value",
        "ldap_hostdn": "cn=owncl-09897738,cn=memberserver,cn=computers,dc=bldomain,dc=com",
        "APACHE_RUN_DIR": "\/var\/run\/apache2",
        "LOCALE": "en_US.UTF-8:UTF-8 de_DE.UTF-8:UTF-8",
        "OWNCLOUD_MARKETPLACE_CA": "no value",
        "LDAP_BASE": "dc=bldomain,dc=com",
        "OWNCLOUD_DEFAULT_LANGUAGE": "en",
        "OWNCLOUD_DAV_CHUNK_BASE_DIR": "no value",
        "mysql_autostart": "no",
        "OWNCLOUD": "{}",
        "update_secure_apt": "yes",
        "locale": "en_US.UTF-8:UTF-8 de_DE.UTF-8:UTF-8",
        "OWNCLOUD_CORS_ALLOWED_DOMAINS": "no value",
        "APACHE_PID_FILE": "\/var\/run\/apache2\/apache2.pid",
        "OWNCLOUD_MAINTENANCE": "no value",
        "OWNCLOUD_PRE_SERVER_PATH": "\/etc\/pre_server.d",
        "APACHE_MAX_KEEP_ALIVE_REQUESTS": "100",
        "OWNCLOUD_APPSTORE_URL": "no value",
        "OWNCLOUD_HAS_INTERNET_CONNECTION": "no value",
        "OWNCLOUD_REMEMBER_LOGIN_COOKIE_LIFETIME": "no value",
        "OWNCLOUD_LOG_FILE": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/files\/owncloud.log",
        "OWNCLOUD_LICENSE_KEY": "no value",
        "OWNCLOUD_INTEGRITY_IGNORE_MISSING_APP_SIGNATURE": "no value",
        "OWNCLOUD_LOG_ROTATE_SIZE": "no value",
        "OWNCLOUD_OPERATION_MODE": "no value",
        "APACHE_SERVER_TOKENS": "Prod",
        "OWNCLOUD_FILESYSTEM_CHECK_CHANGES": "no value",
        "OWNCLOUD_CROND_ENABLED": "true",
        "OWNCLOUD_SECRET": "no value",
        "OWNCLOUD_HASHING_COST": "no value",
        "OWNCLOUD_SESSION_LIFETIME": "no value",
        "OWNCLOUD_REDIS_ENABLED": "true",
        "REDIS_PORT_6379_TCP": "tcp:\/\/172.17.0.1:6379",
        "OWNCLOUD_SUB_URL": "\/owncloud",
        "OWNCLOUD_SYNC_ACCOUNT_REACTIVATION": "true",
        "OWNCLOUD_POST_INSTALL_PATH": "\/etc\/post_install.d",
        "OWNCLOUD_OVERWRITE_WEBROOT": "no value",
        "SERVER_ROLE": "memberserver",
        "ldap_server_type": "master",
        "OWNCLOUD_SKIP_CHMOD": "false",
        "OWNCLOUD_LOG_DATE_FORMAT": "no value",
        "OWNCLOUD_SINGLEUSER": "no value",
        "OWNCLOUD_FILELOCKING_ENABLED": "true",
        "OWNCLOUD_DB_PREFIX": "oc_",
        "OWNCLOUD_OVERWRITE_PROTOCOL": "no value",
        "ldap_server_ip": "127.0.0.1",
        "OWNCLOUD_VOLUME_SESSIONS": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/sessions",
        "OWNCLOUD_MAIL_SMTP_PASSWORD": "no value",
        "OWNCLOUD_PROXY": "no value",
        "OWNCLOUD_REDIS_SESSION_LOCK_WAIT_TIME": "20000",
        "REDIS_1_ENV_REDIS_DATABASES": "1",
        "UPDATER_IDENTIFY": "Docker App",
        "repository_app_center_server": "appcenter.software-univention.de",
        "OWNCLOUD_CSRF_DISABLED": "no value",
        "OWNCLOUD_ERRORLOG_LOCATION": "\/dev\/stderr",
        "OWNCLOUD_SHOW_SERVER_HOSTNAME": "no value",
        "TERM": "xterm",
        "OPENID_LOGIN_BUTTON_NAME": "Single Sign-On Login",
        "LDAP_SERVER_IP": "127.0.0.1",
        "OWNCLOUD_MARKETPLACE_APIKEY": "&quot;&quot;",
        "OPENID_SEARCH_MODE": "email",
        "nameserver_external": "true",
        "OWNCLOUD_ADMIN_PASSWORD": "owncloud",
        "OWNCLOUD_SESSION_SAVE_HANDLER": "files",
        "OWNCLOUD_ACCESSLOG_LOCATION": "\/dev\/stdout",
        "OWNCLOUD_MEMCACHED_HOST": "memcached",
        "OWNCLOUD_MAIL_SMTP_TIMEOUT": "no value",
        "APACHE_ADD_DEFAULT_CHARSET": "UTF-8",
        "OWNCLOUD_VERSION_HIDE": "no value",
        "OWNCLOUD_VOLUME_CONFIG": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/conf",
        "OWNCLOUD_PREVIEW_MAX_FILESIZE_IMAGE": "no value",
        "ldap_server_port": "7389",
        "APACHE_TRACE_ENABLE": "Off",
        "OWNCLOUD_MAIL_SMTP_HOST": "no value",
        "OWNCLOUD_MAX_INPUT_TIME": "3600",
        "OWNCLOUD_EXCLUDED_DIRECTORIES": "no value",
        "OWNCLOUD_APPS_DEPRECATED": "no value",
        "OWNCLOUD_OVERWRITE_HOST": "no value",
        "OWNCLOUD_REDIS_1_ENV_REDIS_DATABASES": "1",
        "OWNCLOUD_BACKGROUND_MODE": "cron",
        "OWNCLOUD_SMB_LOGGING_ENABLE": "no value",
        "OWNCLOUD_SYSTEMTAGS_MANAGER_FACTORY": "no value",
        "OWNCLOUD_MAIL_SMTP_DEBUG": "no value",
        "OWNCLOUD_OVERWRITE_COND_ADDR": "no value",
        "ldap_server_name": "ucs-bdc.bldomain.com",
        "OWNCLOUD_VOLUME_ROOT": "\/mnt\/data",
        "OWNCLOUD_UPDATER_SERVER_URL": "no value",
        "OWNCLOUD_UPDATE_CHECKER": "false",
        "OWNCLOUD_OBJECTSTORE_KEY": "no value",
        "OWNCLOUD_OVERWRITE_CLI_URL": "http:\/\/bldomain.com\/owncloud",
        "OWNCLOUD_MEMCACHED_OPTIONS": "no value",
        "LDAP_MASTER_PORT": "7389",
        "OWNCLOUD_ENABLE_AVATARS": "no value",
        "OWNCLOUD_TRUSTED_PROXIES": "no value",
        "OWNCLOUD_OBJECTSTORE_PATHSTYLE": "false",
        "OWNCLOUD_LOG_LEVEL": "3",
        "APACHE_LOCK_DIR": "\/var\/lock\/apache2",
        "OWNCLOUD_CACHE_PATH": "no value",
        "OWNCLOUD_REDIS_SESSION_LOCKING_ENABLED": "1",
        "APACHE_SERVER_ADMIN": "webmaster@localhost",
        "DOMAINNAME": "bldomain.com",
        "NAMESERVER_EXTERNAL": "true",
        "NAMESERVER_OPTION_TIMEOUT": "2",
        "LANG": "C",
        "OWNCLOUD_PREVIEW_MAX_SCALE_FACTOR": "no value",
        "OWNCLOUD_MAX_FILESIZE_ANIMATED_GIFS_PUBLIC_SHARING": "no value",
        "nameserver_option_timeout": "2",
        "APACHE_ACCESS_FILE_NAME": ".htaccess",
        "DOCKER_HOST_NAME": "ucs-bdc.bldomain.com",
        "OWNCLOUD_ENTRYPOINT_INITIALIZED": "true",
        "OWNCLOUD_SKELETON_DIRECTORY": "no value",
        "REDIS_1_ENV_CRON_ENABLED": "false",
        "MYSQL_AUTOSTART": "no",
        "OWNCLOUD_DB_PASSWORD": "07070690654f9ad7e1618e89e330260f86ea6ea6f0d3a51e6a498046f6697395",
        "OWNCLOUD_MAX_UPLOAD": "20G",
        "OWNCLOUD_LOST_PASSWORD_LINK": "true",
        "OWNCLOUD_PREVIEW_LIBREOFFICE_PATH": "no value",
        "OWNCLOUD_ACCOUNTS_ENABLE_MEDIAL_SEARCH": "no value",
        "OWNCLOUD_FILESYSTEM_CACHE_READONLY": "no value",
        "OWNCLOUD_MEMCACHED_PORT": "11211",
        "DEBIAN_FRONTEND": "noninteractive",
        "OWNCLOUD_MAIL_SMTP_PORT": "no value",
        "APACHE_LOG_LEVEL": "warn",
        "OWNCLOUD_CHECK_FOR_WORKING_WELLKNOWN_SETUP": "no value",
        "OWNCLOUD_OBJECTSTORE_VERSION": "2006-03-01",
        "OWNCLOUD_PRE_CRONJOB_PATH": "\/etc\/pre_cronjob.d",
        "APACHE_LISTEN": "8080",
        "OWNCLOUD_QUOTA_INCLUDE_EXTERNAL_STORAGE": "no value",
        "OWNCLOUD_DB_TIMEOUT": "180",
        "REDIS_1_PORT": "tcp:\/\/172.17.0.1:6379",
        "OWNCLOUD_FORWARDED_FOR_HEADERS": "no value",
        "REPOSITORY_ONLINE_SERVER": "https:\/\/updates.software-univention.de\/",
        "APACHE_RUN_GROUP": "www-data",
        "APACHE_RUN_USER": "www-data",
        "OPENID_AUTO_REDIRECT_TO_IDP": "false",
        "APACHE_ENTRYPOINT_INITIALIZED": "true",
        "locale_default": "en_US.UTF-8:UTF-8",
        "OWNCLOUD_DB_HOST": "172.17.42.1:3306",
        "NAMESERVER1": "192.168.2.79",
        "APACHE_SERVER_NAME": "localhost",
        "OWNCLOUD_POST_SERVER_PATH": "\/etc\/post_server.d",
        "OWNCLOUD_PREVIEW_MAX_X": "no value",
        "server_role": "memberserver",
        "OWNCLOUD_VERSIONS_RETENTION_OBLIGATION": "no value",
        "OWNCLOUD_REDIS_1_ENV_CRON_ENABLED": "false",
        "OWNCLOUD_FILES_EXTERNAL_ALLOW_NEW_LOCAL": "no value",
        "OWNCLOUD_SHARING_MANAGER_FACTORY": "no value",
        "OWNCLOUD_APPS_INSTALL": "no value",
        "REDIS_1_PORT_6379_TCP_ADDR": "172.17.0.1",
        "OWNCLOUD_PROTOCOL": "http",
        "REDIS_ENV_REDIS_DATABASES": "1",
        "APACHE_LOG_FORMAT": "combined",
        "OWNCLOUD_MAIL_SMTP_NAME": "no value",
        "NAMESERVER2": "192.168.2.201",
        "OWNCLOUD_PREVIEW_MAX_Y": "no value",
        "OWNCLOUD_VOLUME_FILES": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/files",
        "LDAP_SERVER_TYPE": "master",
        "OWNCLOUD_REDIS_1_PORT": "tcp:\/\/172.17.0.1:6379",
        "REDIS_1_ENV_TERM": "xterm",
        "NAMESERVER3": "192.168.2.100",
        "REDIS_1_NAME": "\/owncloud_owncloud_1\/redis_1",
        "OWNCLOUD_OBJECTSTORE_AUTOCREATE": "true",
        "OWNCLOUD_CRON_LOG": "no value",
        "OWNCLOUD_TRASHBIN_PURGE_LIMIT": "no value",
        "APACHE_KEEP_ALIVE_TIMEOUT": "5",
        "REPOSITORY_APP_CENTER_SERVER": "appcenter.software-univention.de",
        "OWNCLOUD_USER_SEARCH_MIN_LENGTH": "no value",
        "OPENID_CLIENT_ID": "owncloud",
        "LDAP_MASTER": "ucs-bdc.bldomain.com",
        "OWNCLOUD_ENABLE_CERTIFICATE_MANAGEMENT": "no value",
        "OWNCLOUD_LOG_TIMEZONE": "no value",
        "OWNCLOUD_REDIS_1_PORT_6379_TCP_ADDR": "172.17.0.1",
        "UPDATE_SECURE_APT": "yes",
        "PWD": "\/var\/www\/owncloud",
        "REDIS_1_PORT_6379_TCP_PORT": "6379",
        "OWNCLOUD_DAV_ENABLE_ASYNC": "no value",
        "OWNCLOUD_DB_TYPE": "mysql",
        "OWNCLOUD_REDIS_PASSWORD": "no value",
        "OWNCLOUD_TEMP_DIRECTORY": "no value",
        "OWNCLOUD_APPS_DISABLE": "no value",
        "update_warning_releasenotes": "no",
        "OWNCLOUD_MOUNT_FILE": "no value",
        "OWNCLOUD_MAIL_SMTP_MODE": "no value",
        "OWNCLOUD_MARKETPLACE_KEY": "&quot;&quot;",
        "OWNCLOUD_DB_FAIL": "true",
        "OWNCLOUD_SQLITE_JOURNAL_MODE": "no value",
        "LDAP_SERVER_PORT": "7389",
        "REDIS_1_PORT_6379_TCP_PROTO": "tcp",
        "OWNCLOUD_REDIS_1_NAME": "\/owncloud_owncloud_1\/owncloud_redis_1",
        "OWNCLOUD_REDIS_1_ENV_TERM": "xterm",
        "OWNCLOUD_APPS_ENABLE": "no value",
        "OWNCLOUD_MEMCACHE_LOCAL": "\\OC\\Memcache\\APCu",
        "OWNCLOUD_MEMCACHE_LOCKING": "no value",
        "OWNCLOUD_REDIS_TIMEOUT": "no value",
        "repository_online_server": "https:\/\/updates.software-univention.de\/",
        "updater_identify": "Docker App",
        "OWNCLOUD_MAIL_DOMAIN": "no value",
        "OWNCLOUD_MAIL_SMTP_AUTH_TYPE": "no value",
        "OWNCLOUD_REDIS_HOST": "redis",
        "OWNCLOUD_MEMCACHED_ENABLED": "false",
        "domainname": "bldomain",
        "OWNCLOUD_DEBUG": "no value",
        "OWNCLOUD_PART_FILE_IN_STORAGE": "no value",
        "OWNCLOUD_REDIS_1_PORT_6379_TCP_PORT": "6379",
        "OWNCLOUD_DB_PORT": "3306",
        "LDAP_HOSTDN": "cn=owncl-09897738,cn=memberserver,cn=computers,dc=bldomain,dc=com",
        "OWNCLOUD_APPS_UNINSTALL": "no value",
        "LOCALE_DEFAULT": "en_US.UTF-8:UTF-8",
        "OWNCLOUD_REDIS_1_PORT_6379_TCP_PROTO": "tcp",
        "APACHE_TIMEOUT": "300",
        "LDAP_SERVER_NAME": "ucs-bdc.belldesign.com",
        "OWNCLOUD_PRE_INSTALL_PATH": "\/etc\/pre_install.d",
        "OWNCLOUD_SKIP_CHOWN": "false",
        "ldap_base": "dc=belldesign,dc=com",
        "OWNCLOUD_MINIMUM_SUPPORTED_DESKTOP_VERSION": "no value",
        "REDIS_ENV_CRON_ENABLED": "false",
        "owncloud": "{}",
        "OWNCLOUD_HTACCESS_REWRITE_BASE": "\/owncloud",
        "OWNCLOUD_TRASHBIN_RETENTION_OBLIGATION": "&quot;auto&quot;"
As far as i know there also is a file-size limitation set in Owncloud webinterface in the admin-settings.
https://doc.owncloud.org/server/9.0/admin_manual/configuration_files/big_file_upload_configuration.html
I looked for that but it doesnt show in my version for some reason … I am starting to think it is a bug in UCS 5 as I have tried everything 4-5x now. Thanks for your help!
I did find a strange behavior - cannot restart apache within the owncloud container
Seems, that you will need to restart the UCS-server.
