Hello all,
i’ve setuped new ubuntu 18.04 lxc. I would like to join the sambapart to UCS for fileshareing. Is for this an howto available? Using here UCS 4.4.1.
Thank a lot
Hello all,
Thank a lot
have you tried univention-domain-join
beste reguards
pider
@pider That doesn’t join a Ubuntu Samba to the domain.
@boospy But it should be possible to use this tool. But afterwards you have to join Samba manually like it’s done in this guide.
You have to create a /etc/samba/smb.conf:
[global]
workgroup = MYUBUNTU
client signing = yes
client use spnego = yes
kerberos method = secrets and keytab
realm = MYUBUNTU.EXAMPLE.COM
security = ads
Afterwards you could try the Samba join:
sudo kinit Administrator
sudo net ads join -k
But I haven’t tested this, so there is no guarantee that this will work.
Very thanks for the answer. I also found this too: https://docs.software-univention.de/domain-4.4.html was very important because the jointool for systemonly did not work with LXC’s.
Will join my local machines samba to ucs. Hope it will work. After i write back here
