A few weeks ago, I added two users using udm (specific command see below) and since then I always get
Internal server error: The module process died unexpectedly.
In /var/log/univention/management-console-server.log I see these lines:
12.07.21 12:46:49.653 MAIN ( PROCESS ) : running: ['/usr/bin/python2.7', '/usr/sbin/univention-management-console-module', '-m', 'udm', '-s', '/var/run/univention-management-console/2766-1626086809653.socket', '-d', '2', '-l', 'en_US.UTF-8']
12.07.21 12:46:49.667 MAIN ( PROCESS ) : LDAP bind for user 'uid=Administrator,cn=users,dc=example,dc=com'.
12.07.21 12:47:01.449 MAIN ( WARN ) : Socket died (module=udm)
12.07.21 12:47:01.449 MAIN ( WARN ) : Module process udm died (pid: 15758, exit status: -1, signal: -1, status: -1)
12.07.21 12:47:01.449 MAIN ( WARN ) : Cleaning up requests
12.07.21 12:47:01.449 MAIN ( WARN ) : Invalidating all pending requests 162608682093190-160
12.07.21 12:47:01.449 MAIN ( WARN ) : Remove inactivity timer
12.07.21 12:47:01.449 MAIN ( PROCESS ) : ModuleProcess: stopping 15758
12.07.21 12:47:56.505 MAIN ( PROCESS ) : running: ['/usr/bin/python2.7', '/usr/sbin/univention-management-console-module', '-m', 'udm', '-s', '/var/run/univention-management-console/2766-1626086876504.socket', '-d', '2', '-l', 'en_US.UTF-8']
12.07.21 12:47:57.786 MAIN ( WARN ) : Socket died (module=udm)
12.07.21 12:47:57.786 MAIN ( WARN ) : Module process udm died (pid: 15900, exit status: -1, signal: -1, status: -1)
12.07.21 12:47:57.786 MAIN ( WARN ) : Cleaning up requests
12.07.21 12:47:57.786 MAIN ( WARN ) : Invalidating all pending requests 162608687648812-161
12.07.21 12:47:57.787 MAIN ( WARN ) : Remove inactivity timer
12.07.21 12:47:57.787 MAIN ( PROCESS ) : ModuleProcess: stopping 15900
12.07.21 12:47:57.787 MAIN ( WARN ) : Socket died (module=udm)
As I said, there were two new accounts. When scrolling the user account list, the error appears twice, each time on querying the server for fetching the next few accounts. The first account is in the first batch of entries to be fetched, the second one in the second batch.
udm users/user create --set username="first.last" --set firstname="First" --set lastname="Last" \
--set displayName="First Last" --position "cn=Kollegium,cn=users,dc=example,dc=com" \
--set password='^T@/KNX;QC{2PrJ+hwGn{lF&' --set description="Job Title" --set department="Team Service" \
--set secretary="uid=superior_first.superior_last,cn=Kollegium,cn=users,dc=example,dc=com" \
--set groups="cn=Team Service,cn=Organisation,cn=groups,dc=example,dc=com" \
--set mailPrimaryAddress="first.last@example.com" --set e-mail="first.last@example.com" \
--set PasswordRecoveryEmail="first.last@example.com" --set PasswordRecoveryEmailVerified=TRUE \
--set phone="+49<redacted>"
The password has already been changed, so I won’t redact it. Maybe the problem is in there. The command executed without error message (disclaimer: it did. I am just not sure if this is the correct entry from the history, but it’s the first one found using Ctrl+r, so it should be the last one used, which completed successfully).
In /var/log/univention/management-console-module-udm.log I get:
12.07.21 13:03:57.547 DEBUG_INIT
12.07.21 13:03:58.035 MODULE ( PROCESS ) : Loading python module.
12.07.21 13:03:58.185 MODULE ( PROCESS ) : Imported python module.
12.07.21 13:03:58.185 MODULE ( PROCESS ) : Module instance created.
12.07.21 13:03:58.185 MODULE ( PROCESS ) : Module socket initialized.
12.07.21 13:03:58.203 MODULE ( PROCESS ) : Setting auth type to None
12.07.21 13:03:58.204 MODULE ( PROCESS ) : Setting auth type to None
12.07.21 13:03:58.206 MODULE ( PROCESS ) : Setting user LDAP DN u'uid=Administrator,cn=users,dc=secuinfra,dc=com'
12.07.21 13:03:58.206 MODULE ( PROCESS ) : Setting auth type to None
12.07.21 13:03:58.209 MODULE ( PROCESS ) : Initializing module.
12.07.21 13:03:58.222 MAIN ( PROCESS ) : LDAP bind for user u'uid=Administrator,cn=users,dc=secuinfra,dc=com'.
12.07.21 13:04:03.150 MAIN ( WARN ) : Shutting down all open connections
12.07.21 13:04:03.156 MODULE ( ERROR ) : Traceback (most recent call last):
File "/usr/sbin/univention-management-console-module", line 120, in <module>
notifier.loop()
File "/usr/lib/python2.7/dist-packages/notifier/nf_generic.py", line 304, in loop
step()
File "/usr/lib/python2.7/dist-packages/notifier/nf_generic.py", line 295, in step
__min_timer = dispatch.dispatcher_run()
File "/usr/lib/python2.7/dist-packages/notifier/dispatch.py", line 75, in dispatcher_run
if not disp():
File "/usr/lib/python2.7/dist-packages/notifier/threads.py", line 161, in _simple_threads_dispatcher
task.announce()
File "/usr/lib/python2.7/dist-packages/notifier/threads.py", line 139, in announce
self._callback(self, self._result)
File "/usr/lib/python2.7/dist-packages/notifier/__init__.py", line 104, in __call__
return self._function(*tmp, **self._kwargs)
File "/usr/lib/python2.7/dist-packages/univention/management/console/base.py", line 298, in thread_finished_callback
self.finished(request.id, result)
File "/usr/lib/python2.7/dist-packages/univention/management/console/base.py", line 490, in finished
self.result(res)
File "/usr/lib/python2.7/dist-packages/univention/management/console/base.py", line 494, in result
self.signal_emit('success', response)
File "/usr/lib/python2.7/dist-packages/notifier/signals.py", line 84, in signal_emit
self.__signals[signal].emit(*args)
File "/usr/lib/python2.7/dist-packages/notifier/signals.py", line 49, in emit
cb(*args)
File "/usr/lib/python2.7/dist-packages/univention/management/console/protocol/modserver.py", line 141, in _reply
self.response(msg)
File "/usr/lib/python2.7/dist-packages/univention/management/console/protocol/modserver.py", line 378, in response
self.__queue += bytes(msg)
File "/usr/lib/python2.7/dist-packages/univention/management/console/protocol/message.py", line 140, in __str__
return self.__bytes__()
File "/usr/lib/python2.7/dist-packages/univention/management/console/protocol/message.py", line 342, in __bytes__
return Message._formattedMessage(self._id, self._type, self.mimetype, self.command, body, self.arguments)
File "/usr/lib/python2.7/dist-packages/univention/management/console/protocol/message.py", line 122, in _formattedMessage
data = json.dumps(body)
File "/usr/lib/python2.7/json/__init__.py", line 244, in dumps
return _default_encoder.encode(obj)
File "/usr/lib/python2.7/json/encoder.py", line 207, in encode
chunks = self.iterencode(o, _one_shot=True)
File "/usr/lib/python2.7/json/encoder.py", line 270, in iterencode
return _iterencode(o, 0)
UnicodeDecodeError: 'utf8' codec can't decode byte 0x82 in position 1: invalid start byte
Same error message in both cases. I guess, it would be helpful to know the string that causes that error. Is there a way to switch on debugging?
