I am working on the UCS integration of our plugin for Open-Xchange appsuite, which includes a few OX capabilities that we need to be able to set/unset via the UCS interface. I’m currently considering how to technically go about that. I imagine it would be best to handle this in the same way that the OX integration handles it, but I’m not sure how it does (is the source available to inspect somewhere?).
Is there already an interface for handling OX capabilities via UCS, including authenticating in OX for the RMI jobs and such, or otherwise a method for how best to do that?
there is a generic way to modify any configuration file in the /opt/open-xchange/etc directory via UCR variables. These UCR variables can be set during the package installation, via command line or the UMC web interface. The variables consist of a prefix “ox/cfg”, the name of the configuration file in the “/opt/open-xchange/etc” directory, a property and a value for the property:
-> ucr set ox/cfg/CONFIG_FILENAME/PROPERTY=VALUE
Example:
-> more /opt/open-xchange/etc/permissions.properties| grep permissio
# Default permissions for all users
permissions=
-> ucr set ox/cfg/permissions.properties/permissions=myplugin
# Warning: the value "permissions" has been set via UCR variable "ox/cfg/permissions.properties/permissions" - please alter the UCR variable instead
The integration packages of apps normally handle this kind of configuration in the debian/postinst script of the package, e.g.
#!/bin/bash
#DEBHELPER#
if [ "$1" = "configure" ]; then
module=myplugin
# get the current value
permissions="$(ucr get ox/cfg/permissions.properties/permissions)"
# check if module is already set
if [[ "$permissions" == *"${module}"* ]] ; then
echo "OX permission '$module' already set"
else
echo "Adding OX permission '$module'"
# "${foo:+,}" evaluates to "," if variable foo is non-empty
ucr set ox/cfg/permissions.properties/permissions="$(echo "${permissions}${permissions:+,}$module")"
fi
... more configuration ...
# restart open-xchange
[ -x "/etc/init.d/open-xchange" ] && invoke-rc.d open-xchange restart
fi
I realised I forgot to reply here; I just carried on the email chain instead. Sorry about that.
Is there a way to listen for changes to UCR variables and run scripts after that? Can it be done with a directory listener, for example, or is that outside their scope?
