Installation of OpenProject fails
When trying to install the OpenProject app I am running into an issue that I am not able to solve on my own right now.
root@vsl-xxx-01:/# univention-app install openproject
Resolving dependencies for openproject
Going to install OpenProject (13.4.1)
Password for xxx:
Showing License agreement for openproject=13.4.1
Showing README for openproject=13.4.1
Configuring openproject=13.4.1
Ign:1 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component letsencrypt_20211006103329/all/ InRelease
Hit:2 https://updates.software-univention.de ucs509 InRelease
Ign:3 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component letsencrypt_20211006103329/amd64/ InRelease
Hit:4 https://updates.software-univention.de errata509 InRelease
Hit:5 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component letsencrypt_20211006103329/all/ Release
Hit:6 https://appcenter.software-univention.de/univention-repository/5.0/maintained/component letsencrypt_20211006103329/amd64/ Release
Reading package lists...
Building dependency tree...
Reading state information...
univention-postgresql is already the newest version (12.0.5-1A~5.0.0.202302032056).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
ALTER ROLE
Creating data directories for openproject...
Registering UCR for openproject
Marking openproject=13.4.1 as installed
Multifile: /etc/postgresql/11/main/pg_hba.conf
File: /etc/univention/service.info/services/univention-appcenter.cfg
Setting ports for apache proxy
File: /etc/apache2/sites-available/univention-letsencrypt.conf
Multifile: /etc/apache2/sites-available/000-default.conf
Multifile: /etc/apache2/sites-available/default-ssl.conf
Creating /etc/init.d/docker-app-openproject
Adding localhost to LDAP object
Setting overview variables
Module: create_portal_entries
Reloading apache2 configuration (via systemctl): apache2.service.
univention-postgresql was already set to manually installed.
Checking if database openproject exists (postgresql implementation)
Database openproject already exists
openproject=13.4.1 already has its database
Registering schema /usr/share/univention-appcenter/apps/openproject/openproject.schema
INFO: No change of core data of object openproject.
No modification: cn=openproject,cn=ldapschema,cn=univention,dc=home,dc=intranet
WARNING: cannot append openproject to appidentifier, value exists
Waiting for activation of the extension object openproject: OK
Registering attribute openprojectActivated
Registering attribute openproject-isadmin
Registering the container host openp-48170738 for openproject
Downloading app image docker.software-univention.de/openproject:13.4.1
WARNING! Using --password via the CLI is insecure. Use --password-stdin.
WARNING! Your password will be stored unencrypted in /root/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
Running command: docker pull docker.software-univention.de/openproject:13.4.1
13.4.1: Pulling from openproject
Digest: sha256:55be5c4ea67dfb35d50129cb5d0ccfd47597fb5ebb70b3f681e11005f3d864ca
Status: Image is up to date for docker.software-univention.de/openproject:13.4.1
Initializing app image
Running command: docker create --hostname openp-48170738 --env-file /var/lib/univention-appcenter/apps/openproject/data/../openproject.env -p 40003:80/tcp -v /var/lib/univention-appcenter/apps/openproject/conf:/var/lib/univention-appcenter/apps/openproject/conf -v /sys/fs/cgroup:/sys/fs/cgroup:ro -v /var/lib/univention-appcenter/apps/openproject/data:/var/lib/univention-appcenter/apps/openproject/data -v /etc/apt/apt.conf.d/80proxy:/etc/apt/apt.conf.d/81proxy:ro --tmpfs /run --tmpfs /run/lock --security-opt seccomp:/etc/docker/seccomp-systemd.json -e container=docker docker.software-univention.de/openproject:13.4.1
5cbfc8f3d9ebe8163cfbd08bb200a925c0b91b56e0806c23b5bcd4192056529b
Preconfiguring container 5cbfc8f3d9ebe8163cfbd08bb200a925c0b91b56e0806c23b5bcd4192056529b
Starting docker-app-openproject (via systemctl): docker-app-openproject.service.
Running command: docker cp /etc/postgres-openproject.secret 5cbfc8f3d9ebe8163cfbd08bb200a925c0b91b56e0806c23b5bcd4192056529b:/etc/postgres-openproject.secret
ucr cannot be found, falling back to changing the database file directly
Executing interface restore_data_before_setup for openproject
No interface defined
Executing interface setup for openproject
Copying App Center's setup to container's /usr/share/univention-docker-container-mode/setup_custom
+ mkdir -p /var/lib/univention-appcenter/apps/openproject/data/openproject/files
+ chown app:app /var/lib/univention-appcenter/apps/openproject/data/openproject/files/
++ cat /etc/machine.secret
+ LDAP_PASSWORD=3a55077d5df0e4e375c5e15fd131f225a5b7c374870ed03ba8f230ab2aac4b45
+ sleep 10
+ bundle exec rake 'setting:set[self_registration=3,host_name=vsl-app-01.home.intranet]'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/schema_cache.rb:136:in `load_cache': Ignoring db/schema_cache.yml because it has expired. The current schema version is 0, but the one in the schema cache file is 20240307190126. (StructuredWarnings::StandardWarning)
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/railtie.rb:168:in `block (3 levels) in <class:Railtie>': Ignoring /app/db/schema_cache.yml because it has expired. The current schema version is 20210915154656, but the one in the schema cache file is 20240307190126. (StructuredWarnings::StandardWarning)
rake aborted!
ActiveRecord::StatementInvalid: PG::UndefinedColumn: ERROR:  column "updated_on" of relation "settings" does not exist (ActiveRecord::StatementInvalid)
LINE 1: INSERT INTO "settings" ("name", "value", "updated_on") VALUE...
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/postgresql_adapter.rb:894:in `exec_params'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/postgresql_adapter.rb:894:in `block (2 levels) in exec_no_cache'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract_adapter.rb:1028:in `block in with_raw_connection'
/app/vendor/bundle/ruby/3.2.0/gems/activesupport-7.1.3.2/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract_adapter.rb:1000:in `with_raw_connection'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/postgresql_adapter.rb:893:in `block in exec_no_cache'
/app/vendor/bundle/ruby/3.2.0/gems/activesupport-7.1.3.2/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract_adapter.rb:1143:in `log'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/postgresql_adapter.rb:892:in `exec_no_cache'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/postgresql_adapter.rb:872:in `execute_and_clear'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/postgresql/database_statements.rb:64:in `internal_exec_query'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract/database_statements.rb:153:in `exec_insert'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/postgresql/database_statements.rb:83:in `exec_insert'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract/database_statements.rb:191:in `insert'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract/query_cache.rb:25:in `insert'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/persistence.rb:588:in `_insert_record'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/persistence.rb:1252:in `_create_record'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/counter_cache.rb:187:in `_create_record'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/locking/optimistic.rb:84:in `_create_record'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/encryption/encryptable_record.rb:184:in `_create_record'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/attribute_methods/dirty.rb:240:in `_create_record'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/callbacks.rb:445:in `block in _create_record'
/app/vendor/bundle/ruby/3.2.0/gems/activesupport-7.1.3.2/lib/active_support/callbacks.rb:101:in `run_callbacks'
/app/vendor/bundle/ruby/3.2.0/gems/activesupport-7.1.3.2/lib/active_support/callbacks.rb:952:in `_run_create_callbacks'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/callbacks.rb:445:in `_create_record'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/timestamp.rb:114:in `_create_record'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/persistence.rb:1221:in `create_or_update'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/callbacks.rb:441:in `block in create_or_update'
/app/vendor/bundle/ruby/3.2.0/gems/activesupport-7.1.3.2/lib/active_support/callbacks.rb:952:in `_run_save_callbacks'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/callbacks.rb:441:in `create_or_update'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/timestamp.rb:125:in `create_or_update'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/persistence.rb:751:in `save!'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/validations.rb:55:in `save!'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/transactions.rb:313:in `block in save!'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/transactions.rb:365:in `block in with_transaction_returning_status'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/transactions.rb:361:in `with_transaction_returning_status'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/transactions.rb:313:in `save!'
/app/vendor/bundle/ruby/3.2.0/gems/activerecord-7.1.3.2/lib/active_record/suppressor.rb:56:in `save!'
/app/lib/tasks/setting.rake:36:in `block (3 levels) in <top (required)>'
/app/lib/tasks/setting.rake:32:in `each'
/app/lib/tasks/setting.rake:32:in `block (2 levels) in <top (required)>'
/app/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/exe/rake:27:in `<top (required)>'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/cli.rb:451:in `exec'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/vendor/thor/lib/thor.rb:527:in `dispatch'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/cli.rb:34:in `dispatch'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/cli.rb:28:in `start'
/usr/local/bundle/gems/bundler-2.5.5/exe/bundle:28:in `block in <top (required)>'
/usr/local/bundle/gems/bundler-2.5.5/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/bundle/gems/bundler-2.5.5/exe/bundle:20:in `<top (required)>'
/usr/local/bundle/bin/bundle:25:in `load'
/usr/local/bundle/bin/bundle:25:in `<main>'
Caused by:
PG::UndefinedColumn: ERROR:  column "updated_on" of relation "settings" does not exist (PG::UndefinedColumn)
Tasks: TOP => setting:set
(See full trace by running task with --trace)
Setup script failed!
Aborting...
Going to remove OpenProject (13.4.1)
Executing interface configure for openproject
Stopping docker-app-openproject (via systemctl): docker-app-openproject.service.
Removing localhost from LDAP object
Installing join script /var/cache/univention-appcenter/appcenter.software-univention.de/5.0/openproject_20240326204301.uinst
Search LDAP binddn:  done
Running pre-joinscripts hook(s):  done
Running 01univention-ldap-server-init.inst skipped (already executed)
Running 03univention-directory-listener.inst skipped (already executed)
Running 04univention-ldap-client.inst skipped (already executed)
Running 05univention-bind.inst skipped (already executed)
Running 08univention-apache.inst skipped (already executed)
Running 10univention-ldap-server.inst skipped (already executed)
Running 11univention-heimdal-init.inst skipped (already executed)
Running 11univention-pam.inst skipped (already executed)
Running 15univention-heimdal-kdc.inst skipped (already executed)
Running 18python-univention-directory-manager.inst skipped (already executed)
Running 20univention-directory-policy.inst skipped (already executed)
Running 20univention-join.inst skipped (already executed)
Running 26univention-nagios-common.inst skipped (already executed)
Running 30univention-appcenter.inst skipped (already executed)
Running 30univention-monitoring-client.inst skipped (already executed)
Running 30univention-nagios-client.inst skipped (already executed)
Running 33univention-portal.inst skipped (already executed)
Running 35univention-appcenter-docker.inst skipped (already executed)
Running 35univention-management-console-module-appcenter.inst skipped (already executed)
Running 35univention-management-console-module-diagnostic.inst skipped (already executed)
Running 35univention-management-console-module-join.inst skipped (already executed)
Running 35univention-management-console-module-lib.inst skipped (already executed)
Running 35univention-management-console-module-quota.inst skipped (already executed)
Running 35univention-management-console-module-reboot.inst skipped (already executed)
Running 35univention-management-console-module-services.inst skipped (already executed)
Running 35univention-management-console-module-setup.inst skipped (already executed)
Running 35univention-management-console-module-sysinfo.inst skipped (already executed)
Running 35univention-management-console-module-top.inst skipped (already executed)
Running 35univention-management-console-module-ucr.inst skipped (already executed)
Running 35univention-management-console-module-updater.inst skipped (already executed)
Running 36univention-management-console-module-apps.inst skipped (already executed)
Running 40univention-postgresql.inst skipped (already executed)
Running 50collabora.inst skipped (already executed)
Running 50nextcloud.inst skipped (already executed)
Running 67univention-mail-server.inst skipped (already executed)
Running 81univention-nfs-server.inst skipped (already executed)
Running 82univention-mail-dovecot.inst skipped (already executed)
Running 90univention-bind-post.inst skipped (already executed)
Running 92univention-fetchmail-schema.inst skipped (already executed)
Running 92univention-fetchmail.inst skipped (already executed)
Running 92univention-management-console-web-server.inst skipped (already executed)
Running 98univention-pkgdb-tools.inst skipped (already executed)
Running 51openproject-uninstall.uinst done
Running post-joinscripts hook(s):  done
Potential script hook folder is unused: /var/lib/univention-appcenter/apps/openproject/local/hooks/post-remove.d
Does anyone has an idea what is wrong here?
Or does anyone what files, folders, ucr variables or whatever else needs to be removed to have a clean start.
I am currently running under univention member server 5.0-9 errata1178.
All other docker containers for Nextcloud or Collabra are running and working.
