boospy
December 20, 2020, 10:39pm
1
Hello all,
very strange, but Collabora has uninstalled itself. Maybe the the problem was that on the same server was only office installed too. So now it is now possible to install Collabora again. So i need help with.
Error response from daemon: lstat /var/lib/docker/overlay2/7c1b94a8d82ee224214e96f57b4ed292ecaeb2d0d21b52591ff0f6dce4213cae: no such file or directory
Command docker create --hostname colla-37559987 --env-file /var/lib/univention-appcenter/apps/collabora/collabora.env -p 9980:9980/tcp -v /var/lib/univention-appcenter/apps/collabora/data:/var/lib/univention-appcenter/apps/collabora/data -v /etc/apt/apt.conf.d/80proxy:/etc/apt/apt.conf.d/81proxy:ro -v /sys/fs/cgroup:/sys/fs/cgroup:ro -v /var/lib/univention-appcenter/apps/collabora/conf:/var/lib/univention-appcenter/apps/collabora/conf --restart always --cap-add MKNOD -t --tmpfs /run --tmpfs /run/lock --security-opt seccomp:/etc/docker/seccomp-systemd.json -e container=docker docker.software-univention.de/collabora:6.4.0.14 /bin/sh -c bash start-libreoffice.sh failed with: Error response from daemon: lstat /var/lib/docker/overlay2/7c1b94a8d82ee224214e96f57b4ed292ecaeb2d0d21b52591ff0f6dce4213cae: no such file or directory (1)
Aborting...
I use here here 4.4-7 errata850
Very Thanks and best Regards
Boospy
gulden
January 6, 2021, 4:48pm
2
Hello @boospy ,
this is very strange. Looking the app configurations for Collabora and ONLYOFFICE there is no conflict defined to either one. Besides that, the App Center does not uninstall apps randomly.
Where do you Error response lines come from?
What does /var/log/univention/appcenter.log say?
Best regards,
Nico
boospy
January 6, 2021, 6:52pm
3
I agree. Probably for some reason the deinstallation was suggested and I pressed Y (CMD) there. There were many UCS servers, many updates. It was becoming routine. I probably overlooked something there.
Yes this message is from /var/log/univention/appcenter.log during the installation.
In the meantime I’ve tried that again. After it didn’t work, I reinstalled Onlyoffice. Unfortunately, Onlyoffice is nowhere near as good as Collabora on the web.
gulden
January 12, 2021, 7:50am
4
Hello @boospy ,
thank you very much for your additional feedback.
Best regards,
Nico
boospy
January 14, 2021, 2:56am
5
Ok, this is the whole actual log:
20533 actions.install 21-01-14 03:51:41 [ INFO]: Going to install Collabora Online Development Edition (6.4.0.14)
20533 actions.install 21-01-14 03:51:42 [ DEBUG]: Calling prescript (preinst)
20533 actions.install 21-01-14 03:51:42 [ DEBUG]: Calling /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/collabora_20201029111941.preinst --locale de --binddn uid=loma,cn=osit-user,cn=users,dc=osit,dc=cc --bindpwdfile /tmp/tmpJkK5gs --version 6.4.0.14 --error-file /tmp/tmp47GuhR
20533 actions.install 21-01-14 03:51:42 [ INFO]: Create appcenter/apps/collabora/docker/params
20533 actions.install 21-01-14 03:51:42 [ DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/collabora_20201029111941.preinst returned with 0
20533 packages 21-01-14 03:51:42 [ DEBUG]: Holding LOCK
20533 actions.install 21-01-14 03:51:42 [ INFO]: Creating data directories for collabora...
20533 actions.install 21-01-14 03:51:42 [ INFO]: Copying /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/collabora_20201029111941.univention-config-registry-variables
20533 actions.install.progress 21-01-14 03:51:42 [ DEBUG]: 5
20533 actions.install 21-01-14 03:51:42 [ INFO]: Registering UCR for collabora
20533 actions.install 21-01-14 03:51:42 [ INFO]: Marking collabora=6.4.0.14 as installed
20533 actions.install 21-01-14 03:51:45 [ INFO]: Creating /etc/init.d/docker-app-collabora
20533 actions.install 21-01-14 03:51:45 [ DEBUG]: Calling /usr/sbin/update-rc.d docker-app-collabora defaults 41 14
20533 actions.install 21-01-14 03:51:45 [ DEBUG]: /usr/sbin/update-rc.d returned with 0
20533 actions.install 21-01-14 03:51:45 [ DEBUG]: Calling /bin/systemctl daemon-reload
20533 actions.install 21-01-14 03:51:45 [ DEBUG]: /bin/systemctl returned with 0
20533 actions.install 21-01-14 03:51:45 [ INFO]: Adding localhost to LDAP object
20533 actions.install 21-01-14 03:51:46 [ DEBUG]: Calling /etc/init.d/apache2 reload
20533 actions.install 21-01-14 03:51:46 [ INFO]: Reloading apache2 configuration (via systemctl): apache2.service.
20533 actions.install 21-01-14 03:51:46 [ DEBUG]: /etc/init.d/apache2 returned with 0
20533 actions.install.progress 21-01-14 03:51:46 [ DEBUG]: 10
20533 actions.install.progress 21-01-14 03:51:46 [ DEBUG]: 15
20533 actions.install.progress 21-01-14 03:51:46 [ DEBUG]: 25
20533 actions.install 21-01-14 03:51:46 [ INFO]: Registering the container host colla-27063561 for collabora
20533 actions.install.progress 21-01-14 03:51:46 [ DEBUG]: 30
20533 actions.install 21-01-14 03:51:46 [ INFO]: Downloading app image docker.software-univention.de/collabora:6.4.0.14
20533 docker 21-01-14 03:51:46 [ INFO]: Running command: docker pull docker.software-univention.de/collabora:6.4.0.14
20533 docker 21-01-14 03:51:47 [ INFO]: 6.4.0.14: Pulling from collabora
20533 docker 21-01-14 03:51:47 [ INFO]: 7595c8c21622: Already exists
20533 docker 21-01-14 03:51:47 [ INFO]: d13af8ca898f: Already exists
20533 docker 21-01-14 03:51:47 [ INFO]: 70799171ddba: Already exists
20533 docker 21-01-14 03:51:47 [ INFO]: b6c12202c5ef: Already exists
20533 docker 21-01-14 03:51:47 [ INFO]: 35075541266d: Already exists
20533 docker 21-01-14 03:51:47 [ INFO]: cee04d0fabfc: Already exists
20533 docker 21-01-14 03:51:47 [ INFO]: b90b0e41d326: Already exists
20533 docker 21-01-14 03:51:47 [ INFO]: Digest: sha256:d0dd7e9558a89a631c52a4ad7c1e354604ce401a0f1c138341c5c5ff12df1902
20533 docker 21-01-14 03:51:47 [ INFO]: Status: Image is up to date for docker.software-univention.de/collabora:6.4.0.14
20533 actions.install 21-01-14 03:51:47 [ INFO]: Initializing app image
20533 utils 21-01-14 03:51:47 [ INFO]: Running command: docker create --hostname colla-27063561 --env-file /var/lib/univention-appcenter/apps/collabora/collabora.env -p 9980:9980/tcp -v /var/lib/univention-appcenter/apps/collabora/data:/var/lib/univention-appcenter/apps/collabora/data -v /etc/apt/apt.conf.d/80proxy:/etc/apt/apt.conf.d/81proxy:ro -v /sys/fs/cgroup:/sys/fs/cgroup:ro -v /var/lib/univention-appcenter/apps/collabora/conf:/var/lib/univention-appcenter/apps/collabora/conf --restart always --cap-add MKNOD -t --tmpfs /run --tmpfs /run/lock --security-opt seccomp:/etc/docker/seccomp-systemd.json -e container=docker docker.software-univention.de/collabora:6.4.0.14 /bin/sh -c bash start-libreoffice.sh
20533 utils 21-01-14 03:51:47 [ INFO]: Error response from daemon: lstat /var/lib/docker/overlay2/7c1b94a8d82ee224214e96f57b4ed292ecaeb2d0d21b52591ff0f6dce4213cae: no such file or directory
20533 utils 21-01-14 03:51:47 [ ERROR]: Command docker create --hostname colla-27063561 --env-file /var/lib/univention-appcenter/apps/collabora/collabora.env -p 9980:9980/tcp -v /var/lib/univention-appcenter/apps/collabora/data:/var/lib/univention-appcenter/apps/collabora/data -v /etc/apt/apt.conf.d/80proxy:/etc/apt/apt.conf.d/81proxy:ro -v /sys/fs/cgroup:/sys/fs/cgroup:ro -v /var/lib/univention-appcenter/apps/collabora/conf:/var/lib/univention-appcenter/apps/collabora/conf --restart always --cap-add MKNOD -t --tmpfs /run --tmpfs /run/lock --security-opt seccomp:/etc/docker/seccomp-systemd.json -e container=docker docker.software-univention.de/collabora:6.4.0.14 /bin/sh -c bash start-libreoffice.sh failed with: Error response from daemon: lstat /var/lib/docker/overlay2/7c1b94a8d82ee224214e96f57b4ed292ecaeb2d0d21b52591ff0f6dce4213cae: no such file or directory (1)
20533 packages 21-01-14 03:51:47 [ DEBUG]: Releasing LOCK
20533 actions.install 21-01-14 03:51:47 [CRITICAL]: Error response from daemon: lstat /var/lib/docker/overlay2/7c1b94a8d82ee224214e96f57b4ed292ecaeb2d0d21b52591ff0f6dce4213cae: no such file or directory
20533 actions.install 21-01-14 03:51:47 [ WARNING]: Aborting...
20533 actions.remove 21-01-14 03:51:47 [ DEBUG]: Calling remove
20533 actions.remove.progress 21-01-14 03:51:47 [ DEBUG]: 0
20533 actions.remove 21-01-14 03:51:47 [ INFO]: Going to remove Collabora Online Development Edition (6.4.0.14)
20533 actions.remove 21-01-14 03:51:47 [ DEBUG]: Calling prescript (prerm)
20533 actions.remove 21-01-14 03:51:47 [ DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/collabora_20201029111941.prerm does not exist
20533 packages 21-01-14 03:51:47 [ DEBUG]: Holding LOCK
20533 actions.remove.progress 21-01-14 03:51:47 [ DEBUG]: 5
20533 actions.configure 21-01-14 03:51:47 [ DEBUG]: Calling configure
20533 actions.configure.progress 21-01-14 03:51:47 [ DEBUG]: 0
20533 actions.configure 21-01-14 03:51:47 [ INFO]: Configuring collabora=6.4.0.14
20533 actions.configure 21-01-14 03:51:47 [ DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/collabora_20201029111941.configure_host does not exist
20533 actions.configure.progress 21-01-14 03:51:47 [ DEBUG]: 100
20533 actions.stop 21-01-14 03:51:47 [ DEBUG]: Calling stop
20533 actions.stop.progress 21-01-14 03:51:47 [ DEBUG]: 0
20533 actions.stop 21-01-14 03:51:47 [ DEBUG]: Calling /etc/init.d/docker-app-collabora stop
20533 actions.stop 21-01-14 03:51:48 [ INFO]: Stopping docker-app-collabora (via systemctl): docker-app-collabora.service.
20533 actions.stop 21-01-14 03:51:48 [ DEBUG]: /etc/init.d/docker-app-collabora returned with 0
20533 actions.stop.progress 21-01-14 03:51:48 [ DEBUG]: 100
20533 actions.remove.progress 21-01-14 03:51:48 [ DEBUG]: 45
20533 actions.remove 21-01-14 03:51:48 [ DEBUG]: Calling /usr/sbin/update-rc.d docker-app-collabora remove
20533 actions.remove 21-01-14 03:51:48 [ DEBUG]: /usr/sbin/update-rc.d returned with 0
20533 actions.remove 21-01-14 03:51:48 [ INFO]: Removing localhost from LDAP object
20533 actions.remove 21-01-14 03:51:51 [ DEBUG]: Calling /etc/init.d/apache2 reload
20533 actions.remove 21-01-14 03:51:51 [ INFO]: Reloading apache2 configuration (via systemctl): apache2.service.
20533 actions.remove 21-01-14 03:51:51 [ DEBUG]: /etc/init.d/apache2 returned with 0
20533 actions.remove.progress 21-01-14 03:51:51 [ DEBUG]: 55
20533 actions.remove.progress 21-01-14 03:51:51 [ DEBUG]: 60
20533 actions.remove.progress 21-01-14 03:51:51 [ DEBUG]: 70
20533 actions.remove.progress 21-01-14 03:51:51 [ DEBUG]: 80
20533 actions.remove 21-01-14 03:51:51 [ INFO]: Installing join script /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/collabora_20201029111941.uinst
20533 actions.remove 21-01-14 03:51:51 [ DEBUG]: Calling /usr/sbin/univention-run-join-scripts -dcaccount loma -dcpwd /tmp/tmpFp9LZo
20533 actions.remove 21-01-14 03:51:58 [ WARNING]: Permission denied (publickey,gssapi-keyex,gssapi-with-mic,keyboard-interactive).
20533 actions.remove 21-01-14 03:52:05 [ WARNING]: Permission denied (publickey,gssapi-keyex,gssapi-with-mic,keyboard-interactive).
20533 actions.remove 21-01-14 03:52:10 [ WARNING]: Permission denied (publickey,gssapi-keyex,gssapi-with-mic,keyboard-interactive).
20533 actions.remove 21-01-14 03:52:10 [ INFO]: Search LDAP binddn:
20533 actions.remove 21-01-14 03:52:10 [ INFO]: **************************************************************************
20533 actions.remove 21-01-14 03:52:10 [ INFO]: * Running join scripts failed! *
20533 actions.remove 21-01-14 03:52:10 [ INFO]: * Message: binddn for user loma not found
20533 actions.remove 21-01-14 03:52:10 [ DEBUG]: /usr/sbin/univention-run-join-scripts returned with 1
20533 packages 21-01-14 03:52:10 [ DEBUG]: Releasing LOCK
20533 actions.remove 21-01-14 03:52:10 [ INFO]: Potential script hook folder is unused: /var/lib/univention-appcenter/apps/collabora/local/hooks/post-remove.d
20533 actions.upgrade-search 21-01-14 03:52:10 [ DEBUG]: Calling upgrade-search
20533 actions.upgrade-search.progress 21-01-14 03:52:10 [ DEBUG]: 0
20533 actions.upgrade-search 21-01-14 03:52:10 [ DEBUG]: Checking collabora=6.4.0.14
20533 actions.upgrade-search.progress 21-01-14 03:52:10 [ DEBUG]: 100
20533 actions.remove.progress 21-01-14 03:52:10 [ DEBUG]: 100
20533 utils 21-01-14 03:52:10 [ DEBUG]: send_information: action=install app=collabora value=Error response from daemon: lstat /var/lib/docker/overlay2/7c1b94a8d82ee224214e96f57b4ed292ecaeb2d0d21b52591ff0f6dce4213cae: no such file or directory
status=417
20533 utils 21-01-14 03:52:10 [ DEBUG]: tracking information: {'status': 417, 'uuid': '8081390e-c1c7-485a-910b-0d6df4131e39', 'app': u'collabora', 'value': 'Error response from daemon: lstat /var/lib/docker/overlay2/7c1b94a8d82ee224214e96f57b4ed292ecaeb2d0d21b52591ff0f6dce4213cae: no such file or directory\n', 'version': u'6.4.0.14', 'role': 'domaincontroller_slave', 'action': 'install', 'system-uuid': '2736258f-c9da-4f9d-83e6-387f791b5a80'}
boospy
February 14, 2021, 12:13am
6
Doesn’t anyone else have this topic?
boospy
February 16, 2021, 9:17pm
7
Since the last update this day, i was able to install collabora again. Unfortunately, I don’t know what fixed it now. Anyway, the important thing is that it works again.
