Installation Kopano WebApp schlägt fehl
ich habe auf einem Neuinstallierten UCS Kopano Core installiert. Anschließend wollte ich Kopano WebApp installieren, jedoch schlägt die Installation fehl:
Die Ausführung des Kommandos appcenter/invoke_dry_run ist fehlgeschlagen:
File “/usr/lib/pymodules/python2.7/univention/management/console/base.py”, line 281, in execute
function(self, request)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/init.py”, line 341, in invoke_dry_run
self.invoke(request)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/init.py”, line 129, in _deferred
return func(self, *args, **kwargs)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 656, in _decorated
return function(self, request, *args, **kwargs)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 190, in _response
return function(self, request)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/init.py”, line 515, in invoke
forbidden, warnings = application.check_invokation(function, self.package_manager)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/app_center.py”, line 1244, in check_invokation
return _check(True), _check(False)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/app_center.py”, line 1240, in _check
reason = method(**kwargs)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/app_center.py”, line 1169, in must_have_no_unmet_dependencies
app = app.to_dict(package_manager, domainwide_managed=True)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 648, in wrapper
return func(*args, **kwargs)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/app_center.py”, line 1009, in to_dict
res[‘installations’] = self.get_installations(hosts)
File “/usr/lib/pymodules/python2.7/univention/management/console/ldap.py”, line 141, in _decorated
result = func(*args, **kwargs)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/app_center.py”, line 961, in get_installations
app_objs = appcenter_udm_module.lookup(None, lo, None, base=self.ldap_container)
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/appcenter/app.py”, line 391, in lookup
res.append(object(co, lo, None, dn, attributes=attrs))
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/appcenter/app.py”, line 362, in init
univention.admin.handlers.simpleLdap.init(self, co, lo, position, dn, superordinate, attributes=attributes)
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/init.py”, line 592, in init
self._validate_superordinate()
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/init.py”, line 622, in _validate_superordinate
if self.dn and not self._ensure_dn_in_subtree(self.superordinate.dn, self.lo.parentDn(self.dn)):
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/init.py”, line 627, in _ensure_dn_in_subtree
if self.lo.lo.compare_dn(dn, parent):
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 136, in getattr
self.class.name,repr(name)
AttributeError: ReconnectLDAPObject has no attribute ‘compare_dn’
Der UCS läuft in einer virtuellen Maschine.
Das Problem ist bekannt, wir arbeiten gerade an einem Fix und das Update sollte heute noch veröffentlicht werden: [bug]43550[/bug]. Sobald der Bug auf CLOSED gesetzt wird, einfach aktualisieren, bspw. über das Software Aktualisierungsmodul in UMC oder als root auf der Kommandozeile mit dem Befehl univention-upgrade.
[errata]397[/errata]
