Installation and Setup (Step by Step)
I am just a beginner for UCS
Not sure if I install the server…will it be installed all the apps that you select?
Awaiting to hear from you soon
I think this might be helpful: http://docs.software-univention.de/manual-4.1.html#installation:chapter
To answer your question: the apps you choose, when installing the server, will be installed and its joinscripts will be executed.
Can we install third party security software like Rapid7 and SentinelOne on the Univention Lunix Machine?
thanks
