Import users without WebWeaver synchronization
We are using WebWeaver to synchronise accounts to external system.
For this in the Apps Section in UMC there’s a checkmark.
At the user import with ucs-school-user-import I would like to set this to False, means I want user without WebWeaver sync enabled.
In the config-file in /var/lib/ucs-school-import/configs I tried with
“webweaverActivated”:false,
but this has no effect. There’s no error, but the created user is enabled for this feature,nevertheless.
Can this setting be done in the config file or is there a special hook required to disable this option?
regards, Michael
