biozins
              1
I needed to renew the SSL Certificate. I followed the steps here
After restart IMAP Login (dovecot) is not working with the following error
 dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=192.168.8.158, lip=192.168.8.12, TLS: SSL_read() failed: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca: SSL alert number 48,
session=<7sP0y1e2jdfAqAie>
Seams like dovecot can not find the rootCA. Any hints what I can do to make dovecot and my users happy?
Thanks in advance
Klaus
              Check name and location of the new root certificate and compare it via browser-login with the entries in System - Univention Configuration Registry
On my System with Kopano instead of Dovecot i found the CA in
/etc/univention/ssl/ucsCA/CAcert.pem
Did you restart/reload Apache, Postfix and Dovecot after retrieving the new CA?
