When
Hyper-V enlightment
is enabled (whatever it is?) in the advanced config of a kvm guest libvirt logs show an error as follows and VM hangs on boot:
# tail /var/log/libvirt/libvirtd.log
x86FeatureInData:780 : internal error: unknown CPU feature __kvm_hv_spinlocks
Should be named ‘enlightenment’ btw., shouldn’t it?
…when creating the guest VM with “virt-manager” no problems arise.
(Is using “virt-manager” a good thing at all?)
webermax:
Hyper-V enlightment
Are you enabling this on a Windows-VM?
/KNEBB
Yes, indeed. I just experienced this during the installation process of “Windows Server 2016 Standard Evaluation” on a HP DL380 with two CPU sockets / Intel Xeon.
Linux based VMs are not affected (of course).
