[HowTo] Use letsencrypt certificates for LDAPS connections (via stunnel)
We want to access the UCS LDAP(S) connection with an external service, but with a valid certificate. This example was created during the LDAPS-connection of WebUntis.
Ideas
  • Letsencrypt provides certificates which should be accepted by all external LDAP connections
  • replacing the internally used LDAP certificates is a bad idea, things might break completely
  • it’s possible to use an SSL proxy like nginx
  • but we already have stunnel running :thinking: (in case of UCS 5.0 with univention-saml)
Prerequisities
Warning: the following port mapping works only without Samba/AD installed!
  • stunnel installed: univention-install stunnel4
  • If you upgraded from UCS5.0 to 5.2: rm /etc/stunnel/univention_saml.conf
  • the listening port has to be free & and opened in the Univention firewall
  • e.g., if we use port 636, we check it:
    • ss -nltp | grep 636 - inside
    • sudo nmap <hostname/Ip> -p 636 - outside
  • on my system, port 636 was in use by ldaps (but with the self-signed certificate), so I did ucr set slapd/port/ldaps='7636' and left the firewall settings as is
  • Letsencrypt certificates, the LetsEncrypt App is recommended.
If you use Samba/AD, port 636 shouldn’t be changed, I recommend to use port 8636 instead.
We are going to forward external, SSL encrypted LDAPS connections at port 636 (with Samba: 8636) to our locally running LDAP-Server at port 7389 (unencrypted) by using stunnel for SSL termination.
Put the following in /etc/stunnel/webuntis.conf
; stunnel configuration to allow WebUntis to access an
; officially signed certificate while OpenLDAP still operates
; with the self-signed certificate
; Global configuration
; Certificate/key is needed in server mode and optional in client mode
cert = /etc/univention/letsencrypt/signed_chain.crt
key = /etc/univention/letsencrypt/domain.key
; Some security enhancements for UNIX systems - comment them out on Win32
chroot = /var/lib/stunnel4/
setuid = stunnel4
setgid = stunnel4
; PID is created inside the chroot jail
pid = /stunnel4.pid
options = NO_SSLv3
; Some performance tunings
socket = l:TCP_NODELAY=1
socket = r:TCP_NODELAY=1
; Service-level configuration
[ssl-proxy]
accept = 636
connect = 7389
Now, do a systemctl restart stunnel4.service and :crossed_fingers:
To automate the restart of stunnel when the LetsEncrypt certificates get renewed, we do the following:
cat << EOF > /etc/univention/letsencrypt/post-refresh.d/stunnel
#!/bin/bash
EOF
chmod +x /etc/univention/letsencrypt/post-refresh.d/stunnel
The next time when a LetsEncrypt certifcate is renewed, stunnel gets restarted, too.
Check
  • verify the server certificate by openssl s_client -connect <hostname>:636 -showcerts, should be Letsencrypt
  • start your LDAP connection like before, but now with valid certificates
:fortune_cookie: webuntis
