Howto: Test DDNS Updates
Howto test DDNS updates
Requirements
Use correct DNS backend
Make sure your host uses Samba as backend:
ucr get dns/backend
samba4
Step 1
Get a Kerberos Ticket to authenticate the update:
kinit -t /var/lib/samba/private/dns.keytab dns-$(hostname)
Step 2
Update forward zone:
echo -ne "server 127.0.0.1
update add newhost.$(ucr get domainname) 300 IN A 192.168.0.132
send
"| nsupdate -d -g -t15
Step 3
Verify the entry made is successfully:
host testhost.$(ucr get domainname)
Step 4 (optional)
Update reverse zone. Make sure you use the correct reverse-IP address:
update add 132.0.168.192.in-addr.arpa 300 IN PTR testhost.$(ucr get domainname)
send
Step 5 (optional)
If needed, create a CNAME record:
update add newhost2.$(ucr get domainname) 600 CNAME oldhost.multi.ucs
send
Step 6
Verify entry was updated:
dig -x 192.168.0.132
dig testhost.$(ucr get domainname)
dig newhost2.$(ucr get domainname)
Further Information
Further examples about how to use nsupdate can be found here.
