How to upgrade kopano to 8.7.0
I am running the latest updates on Univention Corporate Server and Kopano 8.6.8.2. I am seeing the problem when using Outlook 2016 and the OLE Client where some emails in Outlook are empty. I have read that there is a bug found in 8.6.8.2 and this problem is fixed in a later release of Kopano. I am running the community edition, i have performed all updates but nothing shows to upgrade to the later version of Kopano which will hopefully then fix the problem.
I used the app center to install Kopano originally, is there a way if -:
There is a manual fix
or
How can i try and upgrade the version of Kopano as other users have posted it has solved the problem.
any help would be appreciated.
thanks,
This is explained in other posts on this forum as well as Staying up to date with Kopano releases on UCS - Blog | Kopano
