How-To: Upgrade from UCS 3.3 to UCS 5
Introduction
UCS 3.3 was released after UCS 4.0. This may lead to difficulties in the upgrade process of the system, as some packages (e.g. Samba) are newer in UCS 3.3 than in UCS 4.0. These instructions will help you to upgrade your UCS 3.3 system to a UCS 5 system.
Note:
Ensure you’ve backed up your UCS 3.3 system before starting the upgrade to facilitate restoration in case of issues. Execute the commands within a screen session or tmux to avoid interruptions and ensure a seamless upgrade process.
Step 1: Prepare the Repository Directory
mkdir -p /var/lib/univention-repository/mirror/3.2/maintained/component/ && cd "$_"
Step 2: Download and Extract Upgrade Components
wget https://updates.software-univention.de/download/temp/transition.tar --no-check-certificate
tar xvf transition.tar
Step 3: Configure the Repository Component for Upgrade
We’ll simulate the current system as UCS 3.2 to ensure that the upgrade process doesn’t mistakenly identify a version higher than 4.0 as currently running:
ucr set repository/online/component/transition=enabled repository/online/component/transition/version=3.2
Step 4: Clean Up the GPG Key
rm transition/*/Release.gpg
Step 5: Initiate the Upgrade Process
univention-upgrade --ignoressh --ignoreterm
