How to:
You can configure the UMC in UCS 5, to open the classic Management interface instead of the default Portal site, similar to older UCS versions. Activating this option will also introduce a new Server entry in the burger menu, from which you can reboot or shutdown the system through the graphical interface.
Step 1: Set the UCRV for the startsite
You have to set the UCR Variable for the startsite to univention/management, so the apache will use this as first.
Default value to reach the Portal site:
ucr get apache2/startsite
univention/
Set the Value to management to reach the old UMC.
ucr set apache2/startsite=univention/management
Setting apache2/startsite
File: /etc/apache2/ucs-sites.conf.d/ucs-sites.conf
Step 2: Restart Services
To apply and use the setting, you have to restart the following Services.
systemctl restart apache2.servicesystemctl restart univention-management-console-server
Step 3 (Optional): Modify the Portal entry login-ucs
After logging out via the burger menu, you will be redirected to univention/portal. To change the behavior so that the portal entry directs users to univention/management on their next login, you must modify the associated portal link.
Default:
udm portals/entry list --filter cn=login-ucs
cn=login-ucs
DN: cn=login-ucs,cn=entry,cn=portals,cn=univention,dc=univention,dc=intranet
activated: TRUE
anonymous: TRUE
backgroundColor: None
description: de_DE: Am Portal anmelden
description: fr_FR: Connectez-vous au portail
description: en_US: Log in to the portal
displayName: en_US: Login
displayName: fr_FR: Connexion
displayName: de_DE: Anmelden
icon: PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0
PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0IiBmaWxsPSJub25lIiBzdHJva2U9IndoaXRlIiBzdHJv
a2Utd2lkdGg9IjIiIHN0cm9rZS1saW5lY2FwPSJyb3VuZCIgc3Ryb2tlLWxpbmVqb2luPSJyb3Vu
ZCIgY2xhc3M9ImZlYXRoZXIgZmVhdGhlci1sb2ctaW4iPjxwYXRoIGQ9Ik0xNSAzaDRhMiAyIDAg
MCAxIDIgMnYxNGEyIDIgMCAwIDEtMiAyaC00Ij48L3BhdGg+PHBvbHlsaW5lIHBvaW50cz0iMTAg
MTcgMTUgMTIgMTAgNyI+PC9wb2x5bGluZT48bGluZSB4MT0iMTUiIHkxPSIxMiIgeDI9IjMiIHky
PSIxMiI+PC9saW5lPjwvc3ZnPgo=
link: en_US: /univention/login/?location=/univention/portal/
linkTarget: samewindow
target: None
To change the link to univention/management:
udm portals/entry modify --dn cn=login-ucs,cn=entry,cn=portals,cn=univention,$(ucr get ldap/base) --set link='"en_US" "/univention/login/?location=/univention/management/"'
New value:
cn=login-ucs
DN: cn=login-ucs,cn=entry,cn=portals,cn=univention,dc=miro,dc=intranet
activated: TRUE
anonymous: TRUE
link: en_US: /univention/login/?location=/univention/management/
target: None
