How-To: Test Connectivity to All LDAP Servers
This guide provides a script to test the connectivity to all LDAP servers in your environment.
  1. Create and Run the Script:
    Copy and paste the following script into your terminal or save it as a shell script (e.g., test_ldap_servers.sh):
    univention-ldapsearch -LLLo ldif-wrap=no univentionService=LDAP cn associatedDomain |
    while IFS=': ' read k v
    do
      case "$k" in
        cn) h=$v ;;
        associatedDomain) d=$v ;;
          ldapsearch -LLL -o ldif-wrap=no -ZZ -D "$(ucr get ldap/hostdn)" -y /etc/machine.secret -h "$h.$d" -p 7389 -s base -b "$(ucr get ldap/hostdn)" dn >/dev/null || echo "FAILED: $h.$d"
          h= d=
      esac
    done
  2. Explanation of the Script:
    • The script starts by using univention-ldapsearch to retrieve all LDAP services.
    • It reads each line of the output, extracting the common name (cn) and associated domain (associatedDomain).
    • For each pair of cn and associatedDomain, it performs an ldapsearch command to test the connection to the LDAP server.
    • If the connection fails, it prints a message indicating which server failed.
  3. Run the Script:
    Execute the script in your terminal:
    bash test_ldap_servers.sh
  4. Check Results:
    • The script will output “FAILED: <hostname>.<domain>” for each LDAP server it could not connect to.
    • If no failures are reported, all LDAP servers are reachable.
