Can somebody explain how to set up properly squid / dansguard? It seems quite simple but it doesnt seem to work. Screenshot of my setup is attached. My goal is 1. Block some unwanted sites 2. See statistics about web usage.
First problem:
I enable squid/contentscan ( enabled by default )
I create variable “dansguardian/groups/IT/banned/sites” and set some domains I want to block, in this case neti.ee and www.google.com
as i understand if the “dansguardian/groups/system” is set to yes the LDAP groups are used. I have created group IT and my user is member of that group. Problem is this setup doesn’t do anything neti.ee and google are accessible.
About the second problem as I understand there is no nice gui / webapp included wich can analyze dansguardian / squid logs?
