How-to: Samba4 - Clean Up Incorrect DNS SRV Records
How to:
This article describes how to identify and remove incorrect SRV records for Samba4 in a Univention Corporate Server (UCS) environment using the samba-tool and the Univention provided check script. This is particularly useful when demoting a Domain Controller or when SRV records still point to decommissioned servers.
1. Validate DNS Records
To verify the current Samba4 DNS setup and identify unwanted SRV records, use the script:
/usr/share/univention-samba4/scripts/check_essential_samba4_dns_records.sh
gc._msdcs.schule.bremen has address 10.0.1.1
_gc._tcp.schule.bremen has SRV record 0 100 3268 master.schule.bremen.
_ldap._tcp.gc._msdcs.schule.bremen has SRV record 0 100 3268 schul-replica.schule.bremen.
_ldap._tcp.gc._msdcs.schule.bremen has SRV record 0 100 3268 master.schule.bremen.
_ldap._tcp.schule.bremen has SRV record 0 100 389 master.schule.bremen.
_ldap._tcp.dc._msdcs.schule.bremen has SRV record 0 100 389 schul-replica.schule.bremen.
_ldap._tcp.dc._msdcs.schule.bremen has SRV record 0 100 389 master.schule.bremen.
_ldap._tcp.pdc._msdcs.schule.bremen has SRV record 0 100 389 master.schule.bremen.
_ldap._tcp.8ee6cdd1-357c-4011-a256-297107772a6f.domains._msdcs.schule.bremen has SRV record 0 100 389 master.schule.bremen.
_kerberos._tcp.dc._msdcs.schule.bremen has SRV record 0 100 88 master.schule.bremen.
_kerberos._tcp.dc._msdcs.schule.bremen has SRV record 0 100 88 schul-replica.schule.bremen.
_kerberos._tcp.schule.bremen has SRV record 0 100 88 master.schule.bremen.
_kerberos._tcp.schule.bremen has SRV record 0 100 88 schul-replica.schule.bremen.
_kerberos._udp.schule.bremen has SRV record 0 100 88 schul-replica.schule.bremen.
_kerberos._udp.schule.bremen has SRV record 0 100 88 master.schule.bremen.
_kpasswd._tcp.schule.bremen has SRV record 0 100 464 master.schule.bremen.
_kpasswd._tcp.schule.bremen has SRV record 0 100 464 schul-replica.schule.bremen.
_kpasswd._udp.schule.bremen has SRV record 0 100 464 master.schule.bremen.
_kpasswd._udp.schule.bremen has SRV record 0 100 464 schul-replica.schule.bremen.
Located DC 'master' in site 'Default-First-Site-Name'
282dceec-4959-49f0-ae73-ef7970df8eeb._msdcs.schule.bremen is an alias for master.schule.bremen.
## Records for site Default-First-Site-Name:
_ldap._tcp.Default-First-Site-Name._sites.schule.bremen has SRV record 0 100 389 schul-replica.schule.bremen.
_ldap._tcp.Default-First-Site-Name._sites.schule.bremen has SRV record 0 100 389 master.schule.bremen.
_ldap._tcp.Default-First-Site-Name._sites.dc._msdcs.schule.bremen has SRV record 0 100 389 master.schule.bremen.
_ldap._tcp.Default-First-Site-Name._sites.dc._msdcs.schule.bremen has SRV record 0 100 389 schul-replica.schule.bremen.
_kerberos._tcp.Default-First-Site-Name._sites.schule.bremen has SRV record 0 100 88 schul-replica.schule.bremen.
_kerberos._tcp.Default-First-Site-Name._sites.schule.bremen has SRV record 0 100 88 master.schule.bremen.
_kerberos._tcp.Default-First-Site-Name._sites.dc._msdcs.schule.bremen has SRV record 0 100 88 schul-replica.schule.bremen.
_kerberos._tcp.Default-First-Site-Name._sites.dc._msdcs.schule.bremen has SRV record 0 100 88 master.schule.bremen.
## Optional GC Records for site Default-First-Site-Name:
_gc._tcp.Default-First-Site-Name._sites.schule.bremen has SRV record 0 100 3268 schul-replica.schule.bremen.
_gc._tcp.Default-First-Site-Name._sites.schule.bremen has SRV record 0 100 3268 master.schule.bremen.
_ldap._tcp.Default-First-Site-Name._sites.gc._msdcs.schule.bremen has SRV record 0 100 3268 master.schule.bremen.
_kerberos.schule.bremen descriptive text "SCHULE.BREMEN"
The output should list only valid and required DNS entries. If you see records for hosts that no longer exist (e.g., schul-replica.schule.bremen), they must be removed.
2. Identify Unwanted SRV Records
Run the following queries to check for DNS records that may need to be deleted:
samba-tool dns query master _msdcs.schule.bremen _kerberos._tcp.dc SRV -P
samba-tool dns query master schule.bremen _kerberos._tcp.schule.bremen SRV -P
samba-tool dns query master schule.bremen _kerberos._udp.schule.bremen SRV -P
samba-tool dns query master schule.bremen _kpasswd._tcp.schule.bremen SRV -P
samba-tool dns query master schule.bremen _kpasswd._udp.schule.bremen SRV -P
samba-tool dns query master schule.bremen _ldap._tcp.Default-First-Site-Name._sites SRV -P
samba-tool dns query master _msdcs.schule.bremen _ldap._tcp.Default-First-Site-Name._sites.dc SRV -P
samba-tool dns query master schule.bremen _kerberos._tcp.Default-First-Site-Name._sites SRV -P
samba-tool dns query master _msdcs.schule.bremen _kerberos._tcp.Default-First-Site-Name._sites.dc SRV -P
samba-tool dns query master schule.bremen _gc._tcp.Default-First-Site-Name._sites SRV -P
3. Delete Incorrect SRV Records
Use the following commands to remove outdated entries pointing to schul-replica.schule.bremen:
samba-tool dns delete master _msdcs.schule.bremen _kerberos._tcp.dc SRV 'schul-replica.schule.bremen 88 0 100' -P
samba-tool dns delete master schule.bremen _kerberos._tcp.schule.bremen SRV 'schul-replica.schule.bremen 88 0 100' -P
samba-tool dns delete master schule.bremen _kerberos._udp.schule.bremen SRV 'schul-replica.schule.bremen 88 0 100' -P
samba-tool dns delete master schule.bremen _kpasswd._tcp.schule.bremen SRV 'schul-replica.schule.bremen 464 0 100' -P
samba-tool dns delete master schule.bremen _kpasswd._udp.schule.bremen SRV 'schul-replica.schule.bremen 464 0 100' -P
samba-tool dns delete master schule.bremen _ldap._tcp.Default-First-Site-Name._sites SRV 'schul-replica.schule.bremen 389 0 100' -P
samba-tool dns delete master _msdcs.schule.bremen _ldap._tcp.Default-First-Site-Name._sites.dc SRV 'schul-replica.schule.bremen 389 0 100' -P
samba-tool dns delete master schule.bremen _kerberos._tcp.Default-First-Site-Name._sites SRV 'schul-replica.schule.bremen 88 0 100' -P
samba-tool dns delete master _msdcs.schule.bremen _kerberos._tcp.Default-First-Site-Name._sites.dc SRV 'schul-replica.schule.bremen 88 0 100' -P
samba-tool dns delete master schule.bremen _gc._tcp.Default-First-Site-Name._sites SRV 'schul-replica.schule.bremen 3268 0 100' -P
Each deletion should return:
Record deleted successfully
4. Verify Clean DNS State
Re-run the diagnostic script to confirm the removal:
Expected output should now only show entries related to the active Domain Controller master.schule.bremen.
5. Summary of Required Records
After cleanup, you should see only these essential DNS entries:
Global Records
gc._msdcs.schule.bremen → A record for 10.0.1.1
_ldap._tcp.schule.bremen, _kerberos._tcp.schule.bremen, _kpasswd._tcp.schule.bremen, etc. → Pointing to master.schule.bremen
MSDCS Records
All pointing to master.schule.bremen
Site-Specific Records
_gc._tcp.Default-First-Site-Name._sites.schule.bremen (optional GC)
Notes
If the demoted server might be reused or rejoined, do not delete its DNS records manually—ensure proper demotion and cleanup.
Always validate with samba-tool dbcheck or univention-check-join-status after DNS cleanup for consistency.
If problems persist after cleanup, consider restarting Samba services or performing a DNS zone reload:
systemctl restart samba-ad-dc
