Good Evening,
I have a Nextcloud installation that has it’s directory at subdomain,domain,com/nextcloud.
Currently, when a user accesses subdomain,domain,com, it takes them to Univention’s Portal instead of nextcloud.
There are two things I am attempting to accomplish.
First, I would like to make Univention’s Portal only accessible over LAN and disable access over WAN.
Second, I would like to have Nextcloud directly accessible at subdomain.domain.com instead of subdomain.domain.com/nextcloud without using a redirect.
I would truly appreciate any help you can provide in how I might accomplish this.
Hello @Vanimox
I did this some time ago, it still works for me:
can someone help me setting up virtual hosts for docker apps (wordpress, nextcloud) in UCS4.2?
I have read the thread VirtualHosts UCS 4.0 - but it didn’t work for me.
What do I have to adopt if the document root is a docker proxy path?
Thanks,
Bernd
There is a simple vhost-solution as well as a vhost-template-solution.
Then:
Not really an answer to that question but perhaps to the problem(?) you thought this to be a solution: Redirect anonymous users to the login-page is a possible setting to protect the portal-page.
Best,
Bernd
