How to reduce entries of ucs-school web import database
Environment
- UCS@school UMC module userimport
- Necessary if Module will not be loaded and a timeout (504) occurs
- Happened in UCS 4.4-5 ucsschool 4.4 v6 but could happen prior and later. Re-verified on UCS-5.0
- Please check status of bug 52173
Diagnostic
Howto verify the problem
Loading of the module takes a long time and ends with an internal server error.
Watch the gunicorn_error.log
tail -f /var/log/univention/ucs-school-import/gunicorn_error.log
during opening the module userimport. If there is still log activity after the 504 error raised the loading of the last import list takes to long.
Step 1: Background information
The module loads the last import information from the django database. You can dump the content by
root@dc0:~ # python3 -m ucsschool.http_api.manage dumpdata --indent 4 import_api.UserImportJob
To delete entries you can use ipython as follows.
Step 2: Start IPython
root@dc0:~ # python3 -m ucsschool.http_api.manage shell
Python 2.7.13 (default, Aug 22 2020, 10:03:02)
[GCC 6.3.0 20170516] on linux2
Type "help", "copyright", "credits" or "license" for more information.
(InteractiveConsole)
Step 3: Choose database
In [1]: from ucsschool.http_api.import_api.models import UserImportJob
Step 4: Get last entry number
In [2]: UserImportJob.objects.last()
Out[2]: <UserImportJob: UserImportJob 321 | dummy9999 (Finished)>
Your result will differ
Step 5: Entry count (optional)
In [3]: UserImportJob.objects.count()
Out[3]: 321
Your result (321) will differ.
Step 6: Delete entries:
You must adapt the number 280 to your environment
In [4]: UserImportJob.objects.filter(id__lt=280).delete()
Out[4]: (279, {u'import_api.UserImportJob': 279})
Step 7: Verify the result in the database (optional)
In [5]: UserImportJob.objects.count()
Out[5]: 42
You close the interactive python shell by pressing Ctrl-D
Step 8: Verify result in module
Now open the module userimport, it should be displayed again
Optional Step: Delete old import jobs
For a faster response and to fix a timeout issue of the import module, you could cleanup all older import jobs and just keep the last 3 of them, with the following python3
script.
clean_user_import_jobs.py (1.1 KB)
Example:
root@dc0:~/univention-support# python3 clean_user_import_jobs.py
Lösche Job: UserImportJob 6 | mejneschool2 (Finished)
Lösche Job: UserImportJob 5 | mejneschool2 (Finished)
Lösche Job: UserImportJob 4 | mejneschool2 (Aborted)
Lösche Job: UserImportJob 3 | mejneschool2 (Finished)
Lösche Job: UserImportJob 2 | mejneschool2 (Finished)
Lösche Job: UserImportJob 1 | mejneschool2 (Finished)
6 Jobs gelöscht, die letzten 3 Jobs werden behalten.
Source Code:
#!/usr/bin/env python3
import os
import sys
import django
# Set up the correct environment
sys.path.append('/usr/lib/python3/dist-packages') # Überprüfe, ob dies benötigt wird
os.environ.setdefault('DJANGO_SETTINGS_MODULE', 'ucsschool.http_api.app.settings')
# Django initialisieren
django.setup()
# Importiere das Model nach dem Django-Setup
# Anzahl der zu behaltenden Jobs
jobs_to_keep = 3
# Alle Jobs nach Erstellungsdatum sortiert abrufen
all_jobs = UserImportJob.objects.all().order_by('-date_created')
# Jobs, die gelöscht werden sollen (alle außer den neuesten `jobs_to_keep` Jobs)
jobs_to_delete = all_jobs[jobs_to_keep:]
# Überprüfen, ob es Jobs zum Löschen gibt
if jobs_to_delete:
for job in jobs_to_delete:
try:
print(f"Lösche Job: {job}")
job.delete()
except Exception as e:
print(f"Fehler beim Löschen von Job {job}: {e}")
print(f"{len(jobs_to_delete)} Jobs gelöscht, die letzten {jobs_to_keep} Jobs werden behalten.")
else:
print(f"Keine Jobs zu löschen, die letzten {jobs_to_keep} Jobs werden behalten.")
