Howto: Managing DHCP Deny Policies for Individual Clients in UCS
Overview
In certain environments, administrators may want to deny specific devices (based on their MAC addresses) from receiving an IP address via DHCP.
Univention Corporate Server (UCS) provides this functionality through DHCP Deny Policies, which can be assigned directly to DHCP host objects.
This article describes how to configure, assign, and remove DHCP Deny Policies using both the Univention Directory Manager (UDM) command line and the Univention Management Console (UMC).
Background
In UCS, DHCP host objects represent individual clients that receive IP addresses via DHCP.
Each host object includes the device’s MAC address, enabling granular control over DHCP assignments.
By applying a DHCP Deny Policy to a specific host object, UCS will instruct the DHCP service to refuse lease assignments for that device.
Prerequisites
- A running DHCP service managed by UCS.
- Administrative privileges on the UCS system.
- Either UDM (command-line) or UMC (web interface) access.
Option 1: Univention Management Console (UMC)
Log in to the Univention Management Console (UMC) with administrative credentials.
Navigate to
Domain → DHCP → [Your DHCP Service] → DHCP Host Object. -
Select the host object corresponding to the device you wish to deny.
Open the Policies tab.
Under Policy: DHCP Allow/Deny, select the desired Deny Policy (for example,
Deny Policy). -
Save the configuration.
Optionally, restart the DHCP service to immediately apply changes:
systemctl restart isc-dhcp-server.service
Once the policy is attached, the specified MAC address will no longer receive a DHCP lease from the UCS-managed DHCP server.
Option 2: Univention Directory Manager (UDM CLI)
Step 1: Verify Existing DHCP Host Object
List the DHCP host object to confirm that the MAC address is correctly registered.
udm dhcp/host list --filter cn=win10-client-02
Example Output:
cn=win10-client-02
DN: cn=win10-client-02,cn=mejneschool2,cn=dhcp,ou=mejneschool2,dc=ucs5schoolhejne,dc=intranet
fixedaddress: 10.200.30.32
host: win10-client-02
hwaddress: ethernet 52:54:00:57:11:63
Step 2: Identify or Create a DHCP Deny Policy
List existing DHCP scope policies to check for a Deny Policy:
udm policies/dhcp_scope list
Example Output:
DN: cn=Deny Policy,cn=scope,cn=dhcp,cn=policies,dc=ucs5schoolhejne,dc=intranet
booting: deny
bootp: deny
declines: deny
duplicates: deny
ldapFilter: None
scopeUnknownClients: deny
If no such policy exists, create one:
udm policies/dhcp_scope create \
--position "cn=scope,cn=dhcp,cn=policies,dc=ucs5schoolhejne,dc=intranet" \
--set name="Deny Policy" \
--set booting=deny \
--set bootp=deny \
--set declines=deny \
--set duplicates=deny \
--set scopeUnknownClients=deny
Step 3: Assign the Deny Policy to the DHCP Host Object
Attach the Deny Policy to the host object using its DN:
udm dhcp/host modify \
--dn "cn=win10-client-02,cn=mejneschool2,cn=dhcp,ou=mejneschool2,dc=ucs5schoolhejne,dc=intranet" \
--policy-reference="cn=Deny Policy,cn=scope,cn=dhcp,cn=policies,dc=ucs5schoolhejne,dc=intranet"
Expected Output:
Object modified: cn=win10-client-02,cn=mejneschool2,cn=dhcp,ou=mejneschool2,dc=ucs5schoolhejne,dc=intranet
Verify:
Example Output:
cn=win10-client-02
univentionPolicyReference: cn=Deny Policy,cn=scope,cn=dhcp,cn=policies,dc=ucs5schoolhejne,dc=intranet
Step 4: Remove the Deny Policy (if needed)
To remove the policy and allow DHCP access again:
--policy-dereference="cn=Deny Policy,cn=scope,cn=dhcp,cn=policies,dc=ucs5schoolhejne,dc=intranet"
Expected Output:
Verification
Restart the DHCP service to ensure the configuration is applied:
Attempt to obtain a lease from the denied MAC address.
If the policy is active, the DHCP request will be rejected.
Summary
| Action | Method | Command / Location |
| List DHCP host object | CLI | udm dhcp/host list --filter cn=<hostname> |
| Assign Deny Policy | CLI | --policy-reference=<policy DN> |
| Remove Deny Policy | CLI | --policy-dereference=<policy DN> |
| Apply Policy | UMC | Domain → DHCP → DHCP-Service → DHCP Host Object → Policies → Policy: DHCP Allow/Deny |
By using DHCP Deny Policies, UCS administrators can selectively block DHCP assignments for specific MAC addresses without modifying subnet-wide settings.
