How-to: Maintenance Mode for Nextcloud in UCS
Overview
When upgrading Nextcloud in a Univention Corporate Server (UCS) environment, it is recommended to enable maintenance mode beforehand. This prevents users from accessing the application during the update, thereby avoiding data inconsistencies or unexpected errors.
This article describes the safest way to update Nextcloud when it is running as a Univention App in a Docker container.
Step 1: Identify the Running Container
Check which Nextcloud container is currently running:
root@nc001:~# docker ps
CONTAINER ID   IMAGE                                               COMMAND                  CREATED        STATUS       PORTS                                     NAMES
55a25fb4010f   docker.software-univention.de/nextcloud:29.0.11-0   "/bin/sh -c /usr/sbi…"   5 months ago   Up 4 weeks   0.0.0.0:40000->80/tcp, :::40000->80/tcp   clever_chaplygin
Step 2: Enable Maintenance Mode
Before starting the upgrade, enable maintenance mode to prevent user access:
univention-app shell nextcloud sudo -u www-data /var/www/html/occ maintenance:mode --on
Maintenance mode enabled
Verify that it is enabled:
Maintenance mode is currently enabled
Step 3: Update the App Center and Upgrade Nextcloud
First, update the Univention App Center:
univention-app update
Then upgrade the Nextcloud application:
univention-app upgrade nextcloud
Step 4: Verify the Upgrade
After the upgrade is complete, check the installed Nextcloud version:
root@nc001:~# univention-app info
UCS: 5.0-10 errata1294
Installed: nextcloud=30.0.15-0
Upgradable:
Confirm that a new container is running with the updated version:
2988ae3333db   docker.software-univention.de/nextcloud:30.0.15-0   "/bin/sh -c /usr/sbi…"   4 minutes ago   Up 4 minutes   0.0.0.0:40000->80/tcp, :::40000->80/tcp   intelligent_joliot
Step 5: Disable Maintenance Mode
Once the upgrade is complete and verified, disable maintenance mode to allow users to access Nextcloud again:
univention-app shell nextcloud sudo -u www-data /var/www/html/occ maintenance:mode --off
Maintenance mode disabled
Conclusion
By enabling and disabling maintenance mode during a Nextcloud upgrade in UCS, administrators can ensure a safe and consistent update process without user interruptions or data corruption.
