This guide will show you how to identify the sources of installed packages on your system using a small Python script. This script parses the output of
apt-cache policyto determine where each package came from.
First, create a new Python file (e.g., check.py) and copy the following script into it:
#!/usr/bin/env python
# Should be written with python-apt
# but for now parse the output of apt-cache policy
import os
import re
command = "apt-cache policy $(dpkg -l | awk '/ii/ {print $2}' )"
stream = os.popen(command)
content = stream.readlines()
getOrigin = False
pkgList = []
# Parse the output generated by apt-cache
for s in content:
if(not s.startswith(' ')):
pkg = type('', (), {})() # Create an empty object
pkg.name = s[:-2] # Remove trailing ':\n'
elif(getOrigin):
pkg.origin = re.split('\s+', s)[2]
pkg.suite = re.split('\s+', s)[3]
pkgList.append(pkg)
getOrigin = False
elif(s.startswith(' ***')):
pkg.version = re.split('\s+', s)[2]
getOrigin = True
# Display the list
for pkg in pkgList:
print(pkg.name + '\t'\
+ pkg.version + '\t'\
+ pkg.origin + '\t'\
+ pkg.suite)
After saving the file, you need to make it executable. Open a terminal and run the following command:
chmod +x check.py
Execute the script to see the output, which will list the installed packages along with their versions, origins, and suites:
./check.py
You can filter the output using grep to search for specific information. For example, to search for packages from a particular origin, you can use:
./check.py | grep 'package-name'
