How to:
The appcenter now supports adding custom settings to an app with a
file /var/lib/univention-appcenter/apps/$APP_ID/custom.settings.
This file has the same format as the standard appcenter settings file.
This is only possible for apps that are installed as Docker containers and contain app settings.
Bug 55765
Available in:
Package: univention-appcenter
Version: 9.0.7-6A~5.0.0.202304251504
Branch: ucs_5.0-0
Scope: errata5.0-3
Step 1: Create the custom.settings file and put your ENV in it.
For example for the app Keycloak:
cat /var/lib/univention-appcenter/apps/keycloak/custom.settings
[keycloak/new/setting]
Type = String
Show = Install, Settings
InitialValue = @%@hostname@%@.@%@domainname@%@
Scope = inside
Description = new setting
Step 2: List the ENV.
This step checks whether the entries are listed by the system, but they are not yet in the container.
univention-app configure keycloak --list| grep 'new/setting'
Output:
keycloak/new/setting: ‘primary.five.two’ (new setting)
Step 3: Configure and set the ENV
The environment variable can now be configured with a value as.
univention-app configure keycloak --set keycloak/new/setting="foobar"
Step 4: Check the ENV in the container
The following commands are used to check whether the ENV has been accepted in the container.
1.
univention-app shell keycloak2.
env| grep NEW_SETT
or
docker exec keycloak env| grep NEW_SETT
Output:
KEYCLOAK_NEW_SETTING=foobar
