How-to: Enable UCS Filesystem Quotas using CLI
How to Enable UCS Filesystem Quotas using CLI
Step 1: Get the Name of your partition
Using df -h:
root@ucs-8393:~# df -h /var/lib/samba/sysvol
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda1        20G  5.2G   14G  28% /
→ /dev/sda1
Step 2: Enable / Disable the Quota
Enable the quota:
umc-command -U Administrator quota/partitions/activate -o partitionDevice=${partition_path?}
Disable the quota:
umc-command -U Administrator quota/partitions/deactivate -o partitionDevice=${partition_path?}
Using -y ${password_file?} and -p ${password?} it’s also possible to pass the required password for the process right away.
