This guide provides steps to enable and collect debug logs for the LDAP nameservice provider
libnss-ldap.
Create a Directory for Logs:
First, create a directory where the debug logs will be stored:
mkdir -p /var/log/libnss-ldap -
Configure Debugging in libnss-ldap:
Append the following lines to your
/etc/libnss-ldap.conffile to enable debugging and specify the log directory:echo -e "debug 1\nlogdir /var/log/libnss-ldap" >> /etc/libnss-ldap.conf -
Understanding the Logging Behavior:
- Log Files: Each LDAP query will create a separate log file in the
/var/log/libnss-ldapdirectory. - Standard Error Logging: Debug information will also be logged to
stderr. This means that commands likegetent shadowwill generate extensive debug output, which can also appear in other log files, such as Samba logs.
Example Usage:
After enabling debugging, you can run a command like:
getent shadowThis will produce debug logs in
/var/log/libnss-ldapand print debug information to the terminal.
Note:
- Debugging can produce a large amount of log data, so use it judiciously and disable it once you have gathered the necessary information.
- To disable debugging, simply remove or comment out the
debug 1andlogdir /var/log/libnss-ldaplines from/etc/libnss-ldap.conf.
You may also take a look at:
How To: Debug High CPU Load on LDAP Server
How-To: Troubleshooting LDAP Performance Issues
