How to: Display Domain Users with getent passwd on UCS 5.2
Description:
Starting with UCS 5.2, Univention replaced the deprecated libnss-ldap and libpam-ldap components with the System Security Services Daemon (SSSD). This modification changes the default behavior of the Name Service Switch (NSS). As a result, running the command getent passwd will only list local users by default, whereas in UCS 5.0-10 it also displayed all domain users.
This article explains why this change was introduced and how to configure UCS 5.2 so that both local and domain users are displayed when using getent passwd.
Background
Key changes introduced in UCS 5.2:
- Removal of
libnss-ldapandlibpam-ldap. - SSSD now handles user resolution instead of the legacy NSS LDAP modules.
nscdis no longer used for passwd-related lookups (only for host resolution).- The UCR variables
nscd/passwd/*are deprecated. - By default, SSSD does not enumerate all users (
enumerate = false) to improve system performance and scalability.
Why does this matter?
Previously, setting
ucr set nsswitch/ldap=yes
enabled global LDAP user enumeration. With the SSSD approach, this option only enables SSSD-based lookups but does not automatically enumerate all domain users. This is intentional to:
- Avoid heavy LDAP/AD load in large domains.
- Prevent timeouts and delays when many accounts exist.
- Increase overall responsiveness of authentication services.
Symptoms
Executing
getent passwdonly lists local system users. -
Direct lookups still work as expected:
getent passwd <username> id <username> -
/etc/nsswitch.confappears similar to:passwd: compat systemd sss group: compat systemd extrausers shadow: compat systemd
Configuration:
To restore the behavior from UCS 5.0-10 and display both local and domain users, SSSD enumeration must be explicitly enabled.
Warning: Enabling enumeration may affect performance in environments with a large number of domain users (e.g., more than 10,000).
Step 1: Verify your current SSSD domain
Execute:
hostname -d
Example output:
example.local
Step 2: Create an SSSD configuration override
Create a configuration snippet:
nano /etc/sssd/conf.d/10-enumerate.conf
Add the following content:
[domain/example.local]
enumerate = true
Replace example.local with the domain name from the previous step.
Step 3: Apply correct permissions
chmod 600 /etc/sssd/conf.d/10-enumerate.conf
Step 4: Clear the SSSD cache and restart the service
sss_cache -U
systemctl restart sssd
Step 5: Test the configuration
getent passwd
You should now see both local and domain users listed.
Additional Information
SSSD does not provide shadow password information for domain users. For example,
pam_unixcannot process password aging for these accounts. -
Configuration snippets under
/etc/sssd/conf.d/are update-safe and persist across system updates. -
For large-scale environments, it is recommended not to enable enumeration and instead use:
getent passwd <username> id <username>for on-demand user lookups.
Related Information
- SSSD official documentation: https://sssd.io/
- Univention Docs: Replacement of
libnss-ldapwith SSSD in UCS 5.2 PAM / Local group cache
