HowTo: Disabling Office 365 and OX Access for Students via UCS Attribute Modification
Overview:
Students (or specific user groups) should no longer have access to Microsoft 365 (M365) and/or Open-Xchange (OX) App Suite.
The UCS to Microsoft 365 / OX connection itself should remain intact for other users, but targeted user groups need to be disconnected.
Environment:
UCS environment with active connections to:
- Microsoft 365 (via Univention Office 365 Connector)
- OX App Suite
Users managed in UCS@school with defined
ucsschoolRoleattributes (e.g.,student:school:<OU>). -
Synchronization to Azure Active Directory enabled.
Step 1 – Identify the Target User Role
Determine the role string (ucsschoolRole) of the affected group. Example:
univention-ldapsearch -LLL uid=<username> ucsschoolRole
Example output:
dn: uid=max.muster,cn=schueler,cn=users,ou=mejneschool2,dc=ucs5schoolhejne,dc=intranet
ucsschoolRole: student:school:mejneschool2
This value can be used as TARGET_ROLE in the script below.
Step 2 – Disable Access via Attribute Modification
Create the script /root/disable_services.sh with the following content:
disable_services.sh (767 Bytes)
#!/bin/bash
# Define the role to search for
TARGET_ROLE="student:school:mejneschool2"
echo "Searching for users with role: ${TARGET_ROLE}"
echo "-----------------------------------------------------"
univention-ldapsearch "ucsschoolRole=${TARGET_ROLE}" dn | \
grep '^dn: ' | \
sed 's/^dn: //' | \
while IFS= read -r user_dn
do
if [ -n "$user_dn" ]; then
echo "Processing user: ${user_dn}"
udm users/user modify --dn "${user_dn}" \
--set isOxUser=Not \
--set UniventionOffice365Enabled=0
if [ $? -eq 0 ]; then
echo "User successfully disabled for OX and M365."
else
echo "ERROR modifying user: ${user_dn}" >&2
fi
fi
done
echo "Script completed."
Usage
chmod +x /root/disable_services.sh./root/disable_services.sh
This sets:
isOxUser=Not→ disables OX accessUniventionOffice365Enabled=0→ disables Microsoft 365 access
Step 3 – Synchronization with Azure AD
- Users are disabled and renamed in Azure AD (prefix:
ZZZ_deleted). - Licenses are automatically removed and can be reassigned.
- Objects starting with
ZZZ_deletedcan be manually deleted in the Microsoft 365 Admin Center if required.
Step 4 (Optional) – Removing the Azure AD Connection (Optional)
Check for existing UCR variables:
ucr search --brief office365
Unset unnecessary variables:
ucr unset <Variable>
Remove alias connections if configured:
ls -lah /etc/univention-office365
/usr/share/univention-office365/scripts/manage_adconnections remove <AliasConnection>
For details, see:
Problem: Office 365 AADSTS700027 - Certificate with identifier not registered
Notes
- Always test with a single user before applying changes broadly.
- Ensure the correct
TARGET_ROLEor OU is specified. - The UCS connection to Microsoft 365 / OX remains available for other groups.
- This procedure provides a clean and efficient way to disable M365 and OX access for specific users without disrupting the overall UCS integration.
With this approach, administrators can efficiently disconnect students (or other roles) from Microsoft 365 and OX App Suite by modifying UCS attributes, ensuring a consistent and secure state.
