How to
Samba uses /etc/bind/named.conf.samba4 for the named configuration, but what if you want to add custom entries for the named and make it update resistant? In UCS you will find the following information in several config files.
Step 1: Add custom entries for configuration.
You can add the entries in the template file, you will find under the following path.
/etc/univention/templates/files/etc/bind/named.conf.samba4
Step 2: UCR Commit
Make a commit on the main config to adopt the entries.
ucr commit /etc/bind/named.conf.samba4
Step 3: Restart the service
To use the new settings in the config, restart the service.
systemctl restart bind9
