How to: Configure Default Mail Quota and Pager Attributes Using User Templates in UCS
Summary
In UCS administrators may want to define default values for certain user attributes when creating new accounts. Typical examples are a default pager number or a mail quota.
This can be achieved by using Extended Attributes and enabling them for the User Template module. Once configured, these attributes can be set in a User Template and automatically applied when creating new users.
This article explains how to:
- Create an Extended Attribute for the pager LDAP attribute
- Use it in a User Template
- Configure a default mail quota using the existing Dovecot Extended Attribute
Step 1: Create an Extended Attribute for the Pager field
The LDAP attribute pager exists in the inetOrgPerson object class, but it is not available in user templates by default. To make it usable in user templates, an Extended Attribute must be created.
Run the following command on a UCS system:
udm settings/extended_attribute create \
--position "cn=custom attributes,cn=univention,$(ucr get ldap/base)" \
--set name="CustomPagerNumberAttribute" \
--set CLIName="pagerTelephoneNumber" \
--set ldapMapping="pager" \
--set objectClass="inetOrgPerson" \
--set groupName="Private" \
--set shortDescription="Pager Number" \
--set longDescription="Set the pager telephone number" \
--set tabAdvanced=0 \
--set tabName="Contact" \
--set tabPosition=4 \
--set translationGroupName='"de_DE" "Privat"' \
--set translationLongDescription='"de_DE" "Ermöglicht das Setzen der Pager-Nummer"' \
--set translationShortDescription='"de_DE" "Rufnummer Pager"' \
--set translationTabName='"de_DE" "Kontakt"' \
--set module="settings/usertemplate" \
--set module="users/user" \
--set syntax="string" \
--set mayChange=1 \
--set copyable=1 \
--set default="0175/00000" \
--set fullWidth=1
This command creates a new Extended Attribute that:
Maps to the LDAP attribute
pager -
Appears in the Contact tab
Is available in both
users/usersettings/usertemplate
Defines the default value 0175/00000
Step 2: Create a User Template
Next, create a user template that administrators can select when creating new users.
udm settings/usertemplate create \
--position "cn=templates,cn=univention,$(ucr get ldap/base)" \
--set name="NewUserTemplate" \
--set displayName="<firstname> <lastname>" \
--set primaryGroup="cn=Domain Users,cn=groups,$(ucr get ldap/base)"
When creating a new user in the UCS management interface, this template can be selected.
The pager attribute will automatically be pre-filled with the default value:
0175/00000
Administrators can change this value during user creation if necessary.
Step 3: Use the Mail User Quota
For the mail quota, an Extended Attribute already exists. It is provided by the Dovecot integration and is called:
UniventionDovecotUserQuota
You can verify its presence with:
udm settings/extended_attribute list --filter cn=UniventionDovecotUserQuota
Example output:
DN: cn=UniventionDovecotUserQuota,cn=custom attributes,cn=univention,dc=univention,dc=intranet
CLIName: mailUserQuota
copyable: None
default: 0
deleteObjectClass: 0
disableUDMWeb: None
doNotSearch: 0
fullWidth: 1
groupName: Advanced settings
groupPosition: None
hook: None
ldapMapping: univentionMailUserQuota
longDescription: Mail quota for the user in megabytes (0=no quota)
mayChange: 1
module: users/user
multivalue: 0
notEditable: 0
objectClass: univentionMail
overwritePosition: None
overwriteTab: 0
preventUmcDefaultPopup: None
shortDescription: Mail quota (MB)
syntax: integer
tabAdvanced: 1
tabName: Mail
tabPosition: 4
translationGroupName: de_DE: Erweiterte Einstellungen
translationGroupName: fr_FR: Réglages avancés
translationLongDescription: de_DE: E-Mail-Quota des Benutzers in Megabytes (0=kein Quota)
translationLongDescription: fr_FR: Quota de courrier pour l’utilisateur ou utilisatrice, en mégaoctets (0 = pas de quota)
translationShortDescription: de_DE: E-Mail-Quota (MB)
translationShortDescription: fr_FR: Quota de courrier (Mo)
translationTabName: de_DE: Mail
translationTabName: fr_FR: Courrier
univentionObjectIdentifier: bf23fa2b-5090-4a4e-9428-d0eec84f22b7
valueRequired: 0
version: 2
This attribute stores the mail quota in megabytes.
Step 4: Modify the default Mail Quota and enable it for User Templates
To make the mail quota configurable through User Templates and set a default value, modify the Extended Attribute:
udm settings/extended_attribute modify \
--dn "cn=UniventionDovecotUserQuota,cn=custom attributes,cn=univention,$(ucr get ldap/base)" \
--set default=5 \
--append "module=settings/usertemplate"
This modification:
- Sets the default mail quota to 5 MB
- Makes the attribute available in the User Template module
Result
After completing these steps:
- Pager numbers can be predefined through a User Template
- Mail quotas can also be configured and applied automatically
- Administrators only need to select the desired template when creating new users
This helps standardize user provisioning and ensures that required attributes are set consistently across all newly created accounts.
