How can i change owncloud port ?
Thx
Thx
I fear that this is a challenge which would most likely break things. The ownCloud integration is served by Apache. Any change in Apache would also affect other services in UCS.
You could try to add your own virtualhost config listening to the port you want and add the Proxy-configuration to be found in 000-default.conf and default-ssl.conf there.
Any other solution depends on your use case and your environment.
hth,
Dirk
