Change listener_module Logrotate Configuration
Environment
UCS System with listener_modules (e.g. ox-connector), of which you want to modify the logrotate configuration
Process
Step 1: Get the listener module name
root@ucs-7794:~# univention-directory-listener-ctrl modules | grep ox
3 dovecot-functional-account /usr/lib/univention-directory-listener/system/dovecot_ox_functional_account.py
3 ox-connector /usr/lib/univention-directory-listener/system/ox-connector.py
=> we want ox-connector
Step 2: Configure the wanted settings
Set the rotate frequency (e.g. to daily)
ucr set logrotate/listener-modules/ox-connector/rotate=daily
For supported values please check:
https://linux.die.net/man/8/logrotate
Set the number of logs to keep (e.g. to 60)
ucr set logrotate/listener-modules/ox-connector/rotate/count=60
Disables compression
ucr set logrotate/listener-modules/ox-connector/compress=false
Disables missingok (logfile needs to be present)
ucr set logrotate/listener-modules/ox-connector/missingok=false
Disables notifempty
ucr set logrotate/listener-modules/ox-connector/notifempty=false
Change permissions of created log
ucr set "logrotate/listener-modules/ox-connector/create=600 root adm"
Step 3: Verify configuration
You can check the generated configuration at /etc/logrotate.d/listener-modules
