How to bind Dokuwiki with SAML/SSO to UCS?
Hello all,
we have installed dokuwiki and auth users with LDAP to UCS. So how it is possible to activate SSO/Saml? On this article was called dokuwiki. But i did not find any documentation for this. We using UCS 4.4-3 errata482.
Very Thanks :slight_smile:
Edit: Found this: https://github.com/pitbulk/dokuwiki-saml hmm… looks complicated
Good question…
We already using UCS LDAP/AD as auth backend and for groups, not sure if this plugin supports ldap too or only internal user base…
Maybe nowadays OAuth would be the better choice?
