How to backup and restore my owncloud application
I would like to ask on how to backup the owncloud application and restore it on the new server? I’m looking the solution how do i get the backup of my mysql database and how do I restore it on the new server? Thanks.
please checkout our documentation.
https://doc.owncloud.com/server/10.6/admin_manual/maintenance/
What you basically need is the db, data, config. data and config folders are mounted on the host system so you can just copy those. the backup of your DB should bei in the data folder after you remove the app. You can also manually trigger a backup of your DB.
