How to assign more memory to PHP inside the Nextcloud docker container
Hi there,
I have installed Nextcloud 13.0.6 in a docker container on UCS 4.3 via the Univention App Center. Furthermore, I installed Elasticsearch directly on the UCS. Nextcloud has been set up to access Elasticsearch.
The connection from Nextcloud to Elasticsearch works fine. When I enter the Nextcloud docker container, I can successfully run the following command:
sudo -u www-data /var/www/html/occ fulltextsearch:test
However, when I start the index, the following command leads to a “Force quit” after a while. Furthermore, the indexing does not really start:
sudo -u www-data /var/www/html/occ fulltextsearch:index
I wonder whether there is enough memory assigned to the docker container. Unfortunately, I do not have experience with docker containers and also not with debugging PHP. Does anybody has some hints?
Best regards,
Peter
Crosspost from https://github.com/nextcloud/univention-app/issues/70
