How-To: Add a printer to UCS
How to add a printer to UCS
If your printer is not listed in UMC but you have a Cups driver file (*.ppd) you can add the printer to UCS as follows:
Step 1
Identify the usual place for the printer models and filter for the vendor:
root@master:~# udm settings/printermodel list  --filter cn=HP| grep DN
DN: cn=HP,cn=cups,cn=univention,dc=multi,dc=com
Write down the above DN as this is the location where you are going to add your printer in the following steps.
Step 2
Copy the ppd-file to it’s destination folder:
cp mymodel.ppd /usr/share/ppd/hplip/HP
Step 3
To create a printer share with udm by specifying the copied ppd-file use our documentation.
Replace the settings in the documentation from the ones you got from previous steps.
Step 4
You have to adjust the settings in the UMC to make the ppd file selectable in the UMC
https://docs.software-univention.de/manual/latest/en/print-services/ppd.html
