License installation for version 5.x via the Univention Management Console
Log into the Univention Management Console with the Administrator account
Select System → Welcome
To get a free/Core license, you could request a new license.
Select a license file with the Import license file button. Alternatively, you can enter a license key in the Import license as text field, e.g., using copy&paste, and then convey it by clicking on the Import from text field button.
License installation for version 4.x via the Univention Management Console
- Log into the Univention Management Console with the Administrator account
- Click on the “Administrator” text in the top right and then select License and choose “import new license.”
- Select a license file with the Import license file button. Alternatively, you can enter a license key in the Import license as text field, e.g., using copy&paste, and then convey it by clicking on the Import from text field button.
- After a re-relogin the license is imported
Installing a license via the command line is still the same as in 3.x:
Log on to the master domain controller as the root user and then run the following command:
univention-license-import <license-file>
The following command can be used to display the license information in the command line:
univention-license-check
License installation via the Univention Management Console: → UCS 3.x
- Click on the gear-wheel icon in the top right and then select Import new license.
- Select a license file with the Import license file button. Alternatively, you can enter a license key in the Import license as text field, e.g., using copy, and then convey it by clicking on the Import button.
Installing a license via the command line:
