the update of horde fails with univention-app register: error: Unable to find version 5.2.17-2 of app horde.
We’re on UCS 4.3-1 errata218. Horde runs on a member server, the message is the same regardless of starting the update from the domain controller or the member server.
From the log:
13105 actions.update 18-08-26 16:17:12 [ DEBUG]: Calling update
13105 actions.update.progress 18-08-26 16:17:12 [ DEBUG]: 0
13105 actions.update 18-08-26 16:17:12 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/categories.ini"...
13105 actions.update 18-08-26 16:17:12 [ DEBUG]: ... Not Modified
13105 actions.update 18-08-26 16:17:12 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/rating.ini"...
13105 actions.update 18-08-26 16:17:12 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/license_types.ini"...
13105 actions.update 18-08-26 16:17:12 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/ucs.ini"...
13105 actions.update 18-08-26 16:17:12 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.3/index.json.gz"...
13105 actions.update 18-08-26 16:17:12 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.3/index.json.gz.gpg"...
13105 actions.update 18-08-26 16:17:13 [ DEBUG]: ... Not Modified
13105 actions.update 18-08-26 16:17:13 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.3/all.tar.gpg"...
13105 actions.update 18-08-26 16:17:13 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.2/index.json.gz"...
13105 actions.update 18-08-26 16:17:13 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.2/index.json.gz.gpg"...
13105 actions.update 18-08-26 16:17:13 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.2/all.tar.gpg"...
13105 actions.update 18-08-26 16:17:13 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz"...
13105 actions.update 18-08-26 16:17:13 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz.gpg"...
13105 actions.update 18-08-26 16:17:13 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.1/all.tar.gpg"...
13105 actions.update.progress 18-08-26 16:17:13 [ DEBUG]: 100
13105 actions.upgrade 18-08-26 16:17:16 [ DEBUG]: Calling upgrade
13105 actions.upgrade.progress 18-08-26 16:17:16 [ DEBUG]: 0
13105 actions.upgrade 18-08-26 16:17:16 [ INFO]: Going to upgrade Horde Groupware Webmail Edition (5.2.17-2)
13105 actions.upgrade 18-08-26 16:17:16 [ DEBUG]: Calling prescript (preinst)
13105 actions.upgrade 18-08-26 16:17:16 [ DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.3/horde_20180621115801.preinst does not exist
13105 actions.upgrade.readme 18-08-26 16:17:16 [ DEBUG]: Calling elinks -dump /var/cache/univention-appcenter/appcenter.software-univention.de/4.3/horde_20180621115801.README_UPDATE_EN
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: Changes with version 5.2.17-2
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: This update covers the following topics:
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: * The Horde Hook for the LDAP authentication has been fixed (correct
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: LDAP hostname and port and starttls).
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: Changes with version 5.2.17-1
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: * The Docker container is now based on UCS 4.3, therefor this update
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: replaces the old container.
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: * Horde update to version 5.2.17
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: * From now on the horde configuration files as well as the php settings
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: file
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: (/var/lib/univention-appcenter/apps/horde/etc-horde/php-settings.ini)
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: are stored in a Docker volume
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: /var/lib/univention-appcenter/apps/horde/etc-horde on the Docker Host
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: (/etc/horde in the container) and thus are update safe. Changes to the
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: horde/php configuration can be made in the files in
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: /var/lib/univention-appcenter/apps/horde/etc-horde/ on the Docker host
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: which take effect after a restart of the horde app
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: * During this update the /etc/horde configuration files are copied from
13105 actions.upgrade.readme 18-08-26 16:17:16 [ INFO]: the old to the new container.
13105 packages 18-08-26 16:17:17 [ DEBUG]: Holding LOCK
13105 actions.start 18-08-26 16:17:17 [ DEBUG]: Calling start
13105 actions.start.progress 18-08-26 16:17:17 [ DEBUG]: 0
13105 actions.start 18-08-26 16:17:17 [ DEBUG]: Calling /etc/init.d/docker-app-horde start
13105 actions.start 18-08-26 16:17:17 [ INFO]: Starting docker-app-horde (via systemctl): docker-app-horde.service.
13105 actions.start 18-08-26 16:17:17 [ DEBUG]: /etc/init.d/docker-app-horde returned with 0
13105 actions.start.progress 18-08-26 16:17:17 [ DEBUG]: 100
13105 actions.upgrade 18-08-26 16:17:17 [ INFO]: Executing interface update_available for horde
13105 actions.upgrade.container.db0c 18-08-26 16:17:17 [ DEBUG]: Using container.db0c for container db0cb49ed4ae127ac1eb4deebd0800287147a5aa091c3f7223de254a8c45c854
13105 actions.upgrade.container.db0c 18-08-26 16:17:17 [ DEBUG]: Calling docker exec -u root db0cb49ed4ae127ac1eb4deebd0800287147a5aa091c3f7223de254a8c45c854 /usr/share/univention-docker-container-mode/update_available --app horde --app-version 5.2.17-2 --error-file /var/univention/tmp/tmpT6tCV9
13105 actions.upgrade 18-08-26 16:17:19 [ INFO]: Upgrading app (u'5.2.17-2')
13105 actions.upgrade 18-08-26 16:17:19 [ INFO]: Executing interface update_app_version for horde
13105 actions.upgrade.container.db0c 18-08-26 16:17:19 [ DEBUG]: Using container.db0c for container db0cb49ed4ae127ac1eb4deebd0800287147a5aa091c3f7223de254a8c45c854
13105 actions.upgrade.container.db0c 18-08-26 16:17:19 [ DEBUG]: Calling docker exec -u root db0cb49ed4ae127ac1eb4deebd0800287147a5aa091c3f7223de254a8c45c854 /usr/share/univention-docker-container-mode/update_app_version --username Administrator --app horde --error-file /var/univention/tmp/tmp1gwGDa --password-file /var/univention/tmp/tmpudsOTh --app-version 5.2.17-2
13105 actions.upgrade.container.db0c 18-08-26 16:17:19 [ INFO]: Installing packages for horde=5.2.17-2
13105 actions.upgrade.container.db0c 18-08-26 16:17:22 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz"...
13105 actions.upgrade.container.db0c 18-08-26 16:17:22 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz.gpg"...
13105 actions.upgrade.container.db0c 18-08-26 16:17:22 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.1/all.tar.gpg"...
13105 actions.upgrade.container.db0c 18-08-26 16:17:23 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/categories.ini"...
13105 actions.upgrade.container.db0c 18-08-26 16:17:23 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/rating.ini"...
13105 actions.upgrade.container.db0c 18-08-26 16:17:23 [ INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/license_types.ini"...
13105 actions.upgrade.container.db0c 18-08-26 16:17:23 [ INFO]: Downloading "http://appcenter.software-univention.de/meta-inf/4.1/all.tar.zsync"...
13105 actions.upgrade.container.db0c 18-08-26 16:17:27 [ WARNING]: usage: univention-app register [-h] [--noninteractive] [--username USERNAME]
13105 actions.upgrade.container.db0c 18-08-26 16:17:27 [ WARNING]: [--pwdfile PWDFILE] [--component] [--files]
13105 actions.upgrade.container.db0c 18-08-26 16:17:27 [ WARNING]: [--host] [--app] [--database] [--attributes]
13105 actions.upgrade.container.db0c 18-08-26 16:17:27 [ WARNING]: [--do-it] [--undo-it]
13105 actions.upgrade.container.db0c 18-08-26 16:17:27 [ WARNING]: [apps [apps ...]]
13105 actions.upgrade.container.db0c 18-08-26 16:17:27 [ WARNING]: univention-app register: error: Unable to find version 5.2.17-2 of app horde. Maybe "/usr/bin/univention-app update" to get the latest list of applications?
13105 actions.upgrade.container.db0c 18-08-26 16:17:27 [ WARNING]: Could not register Component
13105 actions.upgrade 18-08-26 16:17:27 [CRITICAL]: Could not register Component
13105 packages 18-08-26 16:17:27 [ DEBUG]: Releasing LOCK
13105 actions.upgrade 18-08-26 16:17:27 [CRITICAL]: App upgrade script failed
13105 actions.upgrade 18-08-26 16:17:27 [ WARNING]: Aborting...
13105 actions.start 18-08-26 16:17:27 [ DEBUG]: Calling start
13105 actions.start.progress 18-08-26 16:17:27 [ DEBUG]: 0
13105 actions.start 18-08-26 16:17:27 [ DEBUG]: Calling /etc/init.d/docker-app-horde start
13105 actions.start 18-08-26 16:17:27 [ INFO]: Starting docker-app-horde (via systemctl): docker-app-horde.service.
13105 actions.start 18-08-26 16:17:27 [ DEBUG]: /etc/init.d/docker-app-horde returned with 0
13105 actions.start.progress 18-08-26 16:17:27 [ DEBUG]: 100
13105 utils 18-08-26 16:17:27 [ DEBUG]: send_information: action=upgrade app=horde value=None status=431
13105 utils 18-08-26 16:17:27 [ DEBUG]: tracking information: {'status': 431, 'uuid': '6b85fbcb-4a8b-4756-b9f1-21552fddb873', 'app': u'horde', 'version': u'5.2.17-2', 'role': 'memberserver', 'action': 'upgrade', 'system-uuid': '213a29ad-80b0-4b87-b3b6-9743203235f8'}
13105 actions.upgrade-search 18-08-26 16:17:28 [ DEBUG]: Calling upgrade-search
13105 actions.upgrade-search.progress 18-08-26 16:17:28 [ DEBUG]: 0
13105 actions.upgrade-search 18-08-26 16:17:28 [ DEBUG]: Checking horde=5.2.17-2
13105 actions.upgrade-search.progress 18-08-26 16:17:28 [ DEBUG]: 100
13105 actions.upgrade.progress 18-08-26 16:17:28 [ DEBUG]: 100
Can someone please help on this?
Thank you,
Norbert
