installed and work as exspected with one exception:
I found no solution to start the url "https://ucs-xxx.my.domain.com/univention/management"on this memberserver for updates etc.
I always receive an empty screen or “400 Bad request”.
Log “/var/log/haproxy.log” doesn´t help either:
Feb 10 17:31:25 ucs-xxxx haproxy[28465]: 192.168.a.bbb:62630 [10/Feb/2020:17:31:25.180] https-in~ haproxy_servers/haproxy 0/0/10/25/35 400 169 - - SD-- 0/0/0/0/0 0/0 “GET /univention/portal/ HTTP/1.1”
The crux is that haproxy and 'Apache2 listen on the same port.
Would the only solution be to change port 443 in Apache2 config?
If so, how then permanently?
