Guacamole - enable websockets
Hi
Today we set up a Guacamole app via AppCenter for testing. We can connect to Windows clients via RDP without problems. Looking at the logs we see:
11:07:05.592 [http-nio-8080-exec-3] INFO o.a.g.t.h.RestrictedGuacamoleHTTPTunnelServlet - Using HTTP tunnel (not WebSocket). Performance may be sub-optimal.
And the performance is quite poor to be honest on 1Gig LAN.
How would we make WebSockets to work?
Also, Guacamole 0.9.13-incubating is 6 years old now. Is there a way to update it e.g. drop newer .war in the docker?
Thanks.
One thing that comes to mind is that websockts require SSL. Make sure that port 443 is open. If you’re using Apache or NGINX for fowarding you probably need to add some configuration for websocket passthrough.
Mastodon
