I have tried to install the latest updates on my UCS server. After the reboot the systems stops at this grub screen:
Any tips?
Any tips?
Hey,
so you aren’t even able to boot into the system? Then you should try the following:
/mnt
, mount the boot partition on /mnt/boot
(if there’s a separate partition for it)grml-chroot /mnt /bin/bash
grub-install /dev/sda
Kind regards,
mosu
