Hi everyone,
I’ve just deployed Gitlab from the Univention App Center.
In general I’m using letsencrypt wildcard certificates for apache2, postfix and dovecot. Please see my guide here, if you are interested: Letsencrypt app - wildcards supported?
However, I could not figure out how to use these in Gitlab.
I used docker inspect -f '{{ .Mounts }}' gitlab-containerid to check the volumes mounted to the gitlab container:
{bind /var/lib/univention-appcenter/apps/gitlab/conf /var/lib/univention-appcenter/apps/gitlab/conf true rprivate}
{bind /var/lib/univention-appcenter/apps/gitlab/data /var/lib/univention-appcenter/apps/gitlab/data true rprivate}
{bind /var/lib/univention-appcenter/apps/gitlab/logs /var/log/gitlab true rprivate}
{bind /var/lib/univention-appcenter/apps/gitlab/data /var/opt/gitlab true rprivate}
{bind /etc/apt/apt.conf.d/80proxy /etc/apt/apt.conf.d/81proxy ro false rprivate}
{bind /var/lib/univention-appcenter/apps/gitlab/conf /etc/gitlab true rprivate}
{bind /sys/fs/cgroup /sys/fs/cgroup ro false rprivate}
Checking /var/lib/univention-appcenter/apps/gitlab/conf, I can see there is a folder called trusted-certs, which is referenced here: https://docs.gitlab.com/omnibus/settings/ssl.html#install-custom-public-certificates
However, the private key does not seem to be used, which confuses me even more, so I did not follow this guide.
The gitconfig of my client is quite simple, basically I’m using the certificate store of Windows (not domain joined):
[diff "astextplain"]
textconv = astextplain
[filter "lfs"]
clean = git-lfs clean -- %f
smudge = git-lfs smudge -- %f
process = git-lfs filter-process
required = true
[http]
sslBackend = schannel
[core]
autocrlf = true
fscache = true
symlinks = false
editor = \"C:\\\\Program Files\\\\Notepad++\\\\notepad++.exe\" -multiInst -notabbar -nosession -noPlugin
[pull]
rebase = false
[credential]
helper = manager
When I try to clone a repo via HTTPS, I get the following error:
git clone https://host.domain.com:22222/gitlab/groupabc/backend.git
Cloning into 'backend'...
fatal: unable to access 'https://host.domain.com:22222/gitlab/groupabc/backend.git/': schannel: failed to receive handshake, SSL/TLS connection failed
I’d highly appreciate if there’s a gitlab-pro around able to help.
Best regards
pate1337
