Fresh Install Interface errors
Hello i did a fresh install today.
Everything appeared to work at first but some parts of the interface are slow and has missing images.
When i look there are a ton of interface errors. The most obvious is the app center.
Can anyone offer some advice ?
Scared to make the server permanent with these problems.
/univention/js/dojo/dojo.js:6 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
r.getText @ /univention/js/dojo/dojo.js:6
apps-self-service_20151117.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-cups.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-radius.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-samba4.svg Failed to load resource: the server responded with a status of 404 (Not Found)
main.js:1029 Module could not be loaded: umc/modules/reboot
(anonymous) @ main.js:1029
main.js:1029 Module could not be loaded: umc/modules/ipchange
main.js:1029 udm:license-import is not a umc.widgets._ModuleMixin! (2}
main.js:1029 Module could not be loaded: umc/modules/serveroverview
main.js:1029 Module could not be loaded: umc/modules/lib
/univention/js/umc/ Failed to load resource: the server responded with a status of 403 (Forbidden)
/univention/js/dojo/dojo.js:481 e
v @ /univention/js/dojo/dojo.js:481
apps-zuludesk_20170623110026.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-z-push-kopano_20170630110344.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-wordpress_20170405170026.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-wildfly_20170427135336.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-webweaver_20150130.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-webuntis_20161128154633.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-wawision_20170111122721.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-univention-demo-data_20151202.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-ucc_20160811170611.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-ucsschool_20170908162422.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-uvmm.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-tine20_20170428121633.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-tecart_20161214101533.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-digitec-suitecrm_20170810160831.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-pkgdb.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-xrdp_20150902.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-squid.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-privacyidea_20170330115620.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-printquota_20161020173421.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-open-xchange-guard_20170620113648.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-open-xchange-text_20170621095529.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-oxseforucs_20170830120807.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-owncloud82_20170427133539.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-owncloud_20170510145711.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-openvpn4ucs_20170615122531.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-opsi_20160927154325.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-openproject_20170704153410.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-onlyoffice-ds_20170728105017.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-noctua_20170412123612.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-nextcloud_20170905134007.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-nagios.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-mobydick_20150527.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-office365_20161123164032.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-maildisclaimer_20170524102325.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-mail-server.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-m23_20170626182521.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-letsencrypt_20170713143310.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-kvm.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-adtakeover.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-audriga-groupware-migration_20131216.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-uvmm-ec2.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-adconnector.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-asterisk4ucs_20170124094112.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-kopano-webmeetings_20170808134523.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-kopano-webapp_20170530164135.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-kopano-core_20170530164016.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-jenkins_20170502110110.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-klms_20150730.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-horde_20161024154423.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-google-apps_20170714095234.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-filewave_20170629161158.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-fetchmail.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-etherpad-lite_20160722133148.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-egroupware_20170703173428.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-dudle_20160201.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-edyou_20141113.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-dhcp-server.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-kde.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-zimbra_20170117144145.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-collabora_20170904150649.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-benno-mailarchiv_20170619120638.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-bareos_20170213162312.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-bacula_20140910.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-iku-av-proxy_20170103114730.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-auralis_20161219103359.svg Failed to load resource: the server responded with a status of 404 (Not Found)
apps-iku-av-mail_20170103114322.svg Failed to load resource: the server responded with a status of 404 (Not Found)
i have done a little testing.
If i go to the web interface by the dns name i get these issues. If i go to it by the IP Address. everything works fine.
ANy ideas anyone
Hey,
is your installation up to date? You can check by running univention-upgrade via ssh.
Next please try accessing the site via its name once. Now look at the web server log files in /var/log/apache2. Post the lines from access.log whose timestamps match when you accessed the site.
Kind regards,
mosu
Good morning. Yes it is up to date. I ran it again just to be sure.
the access.log is clean.
Here are is the results from the error.log file. Still have 404 and 403 errors.
 tail -f access.log
192.168.136.56 - - [04/Oct/2017:09:00:46 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:01:16 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:01:46 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:02:16 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:02:46 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:03:16 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:03:46 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:04:15 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:04:45 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:05:16 -0400] "POST /univention/get/session-info HTTP/1.1" 200 484 "http://192.168.136.3/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
tail -f error.log
[Wed Oct 04 08:30:36.439881 2017] [autoindex:error] [pid 16864] [client 192.168.136.253:53740] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
[Wed Oct 04 08:31:20.440251 2017] [autoindex:error] [pid 14160] [client 192.168.136.253:53750] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
[Wed Oct 04 08:31:26.308862 2017] [autoindex:error] [pid 21011] [client 192.168.136.253:53752] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
[Wed Oct 04 08:32:57.795216 2017] [autoindex:error] [pid 21024] [client 192.168.136.253:53807] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
[Wed Oct 04 08:34:13.833558 2017] [autoindex:error] [pid 21011] [client 192.168.136.253:53827] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
[Wed Oct 04 08:38:31.873373 2017] [autoindex:error] [pid 21163] [client 192.168.136.56:65487] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
[Wed Oct 04 08:38:36.765901 2017] [autoindex:error] [pid 21163] [client 192.168.136.56:65487] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/login/?location=%2Funivention%2Fmanagement%2F%23module%3Dudm%3Adhcp%2Fdhcp%3A0%3Adhcp%2Fsubnet%3Acn%3D192.168.136.0%2Ccn%3Dozone.bb%2Ccn%3Ddhcp%2Cdc%3Dozone%2Cdc%3Dbb&username=administrator&lang=en-US
[Wed Oct 04 08:42:46.784786 2017] [autoindex:error] [pid 16863] [client 192.168.136.56:49203] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
[Wed Oct 04 08:42:57.192409 2017] [autoindex:error] [pid 21163] [client 192.168.136.56:49205] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
[Wed Oct 04 08:47:48.013274 2017] [autoindex:error] [pid 20840] [client 192.168.136.56:49277] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://192.168.136.3/univention/management/
Your error.log shows different timestamps than the entries from your access.log. Therefore the access.log shown doesn’t really help. Can you please post from access.log from when you tried to access the interface? e.g. around 08:42.
A couple more questions:
  1. Are you using a proxy server?
  2. Have you tried a different web browser?
  3. Have you tried clearing your web browser’s cache?
tail -f access.log
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "HEAD /univention/js/umc/ HTTP/1.1" 403 337 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "POST /univention/command/udm/meta_info HTTP/1.1" 200 500 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "POST /univention/command/udm/containers HTTP/1.1" 200 509 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "POST /univention/command/udm/types HTTP/1.1" 200 497 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "POST /univention/command/udm/reports/query HTTP/1.1" 200 449 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "HEAD /univention/management/modules/udm/wizards/dhcp/service.js HTTP/1.1" 404 809 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "POST /univention/command/udm/properties HTTP/1.1" 200 1857 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "POST /univention/command/udm/layout HTTP/1.1" 200 751 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "POST /univention/command/udm/policies HTTP/1.1" 200 1197 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:23 -0400] "POST /univention/command/udm/values HTTP/1.1" 200 450 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:23 -0400] "POST /univention/command/udm/meta_info HTTP/1.1" 200 499 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:22 -0400] "POST /univention/command/udm/nav/container/query HTTP/1.1" 200 671 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:23 -0400] "POST /univention/command/udm/query HTTP/1.1" 200 687 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.56 - - [04/Oct/2017:09:46:23 -0400] "POST /univention/command/udm/nav/container/query HTTP/1.1" 200 720 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
192.168.136.92 - - [04/Oct/2017:09:46:27 -0400] "POST /univention/get/session-info HTTP/1.1" 200 4067 "https://bar-dom01.ozone.bb/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.79 Safari/537.36 Edge/14.14393"
192.168.136.56 - - [04/Oct/2017:09:46:28 -0400] "POST /univention/get/session-info HTTP/1.1" 200 483 "http://bar-dom01/univention/management/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36"
tail -f error.log
[Wed Oct 04 09:46:22.830301 2017] [autoindex:error] [pid 23867] [client 192.168.136.56:54206] AH01276: Cannot serve directory /var/www/univention/js/umc/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: http://bar-dom01/univention/management/
Chrome console
dojo.js.uncompressed.js:325 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
r.getText @ dojo.js.uncompressed.js:325
dojo.js.uncompressed.js:29260 e
v @ dojo.js.uncompressed.js:29260
/univention/management/modules/udm/wizards/groups/group.js Failed to load resource: the server responded with a status of 404 (Not Found)
dojo.js.uncompressed.js:30359 HEAD http://bar-dom01/univention/js/umc/ 403 (Forbidden)
b @ dojo.js.uncompressed.js:30359
h.xhr @ dojo.js.uncompressed.js:29435
urlExists @ dojo.js.uncompressed.js:44091
checkReloadRequired @ dojo.js.uncompressed.js:44063
(anonymous) @ main.js:1448
(anonymous) @ dojo.js.uncompressed.js:2902
b @ dojo.js.uncompressed.js:6014
then.d.then @ dojo.js.uncompressed.js:6235
openModule @ main.js:1415
(anonymous) @ main.js:1229
(anonymous) @ dojo.js.uncompressed.js:51176
(anonymous) @ dojo.js.uncompressed.js:7008
dojo.js.uncompressed.js:29260 e {message: "Unable to load /univention/js/umc/ status: 403", response: {…}, status: 403, responseText: "", xhr: XMLHttpRequest, …}
(anonymous) @ dojo.js.uncompressed.js:29220
q @ dojo.js.uncompressed.js:22864
p @ dojo.js.uncompressed.js:22845
reject.errback @ dojo.js.uncompressed.js:22940
q @ dojo.js.uncompressed.js:22879
(anonymous) @ dojo.js.uncompressed.js:29455
l @ dojo.js.uncompressed.js:6005
h.reject @ dojo.js.uncompressed.js:6196
a @ dojo.js.uncompressed.js:6061
b @ dojo.js.uncompressed.js:6035
b @ dojo.js.uncompressed.js:6032
e @ dojo.js.uncompressed.js:30192
d @ dojo.js.uncompressed.js:30220
XMLHttpRequest.send (async)
dojo.js.uncompressed.js:30359 HEAD http://bar-dom01/univention/management/modules/udm/wizards/dhcp/service.js 404 (Not Found)
getWizard @ cache.js:135
(anonymous) @ cache.js:152
forEach @ dojo.js.uncompressed.js:4173
_loadWizardMulti @ cache.js:151
(anonymous) @ cache.js:90
resolve @ dojo.js.uncompressed.js:6169
a @ dojo.js.uncompressed.js:6058
b @ dojo.js.uncompressed.js:6029
e @ dojo.js.uncompressed.js:30185
a.(anonymous function) @ dojo.js.uncompressed.js:30017
_request @ dojo.js.uncompressed.js:44276
umcpCommand @ dojo.js.uncompressed.js:44235
getChildModules @ cache.js:105
preloadModuleInformation @ cache.js:86
buildRendering @ udm.js:308
create @ dojo.js.uncompressed.js:15765
postscript @ dojo.js.uncompressed.js:15701
(anonymous) @ dojo.js.uncompressed.js:10310
(anonymous) @ main.js:1441
dojo.js.uncompressed.js:29260 e {message: "Unable to load /univention/management/modules/udm/wizards/dhcp/service.js status: 404", response: {…}, status: 404, responseText: "", xhr: XMLHttpRequest, …}
Thanks. Please try different web browsers, too, e.g. Firefox & Internet Explorer.
