Firewall UCR registry will not accept ipv4 address in rule
I’ve been trying to make some rules more strict so that I can limit a port to an IP and my current rule is the only one that works:
UCR Variable: security/packetfilter/tcp/9102/all
Value: ACCEPT
According to the documentation at https://docs.software-univention.de/developer-reference-4.2.html#misc:nacl:ucr it says this should work:
security/packetfilter/protocol/port(s)/address=policy
So when I try it as below, it doesn’t work.
UCR Variable: security/packetfilter/tcp/9102/172.16.0.99
Value: ACCEPT
What doesn’t work exactly? You’ve to restart the firewall after creating the rule:
systemctl restart univention-firewall.service
I am well aware of needing to restart the firewall service after each change. It still doesn’t work.
So what’s the output of
iptables -L
# iptables -L
Chain INPUT (policy DROP)
target     prot opt source               destination
ACCEPT     udp  --  anywhere             anywhere             udp spt:netbios-ns
ACCEPT     all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http-alt
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:6670
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:ssh
ACCEPT     udp  --  anywhere             anywhere             udp dpts:netbios-ns:netbios-ssn
ACCEPT     udp  --  anywhere             anywhere             udp dpt:microsoft-ds
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:nrpe
ACCEPT     udp  --  anywhere             anywhere             udp dpt:netbios-ns
ACCEPT     udp  --  anywhere             anywhere             udp dpts:32765:32769
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:microsoft-ds
ACCEPT     udp  --  anywhere             anywhere             udp dpt:ntp
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:sunrpc
ACCEPT     tcp  --  anywhere             anywhere             tcp dpts:32765:32769
ACCEPT     tcp  --  anywhere             anywhere             tcp dpts:netbios-ns:netbios-ssn
ACCEPT     udp  --  anywhere             anywhere             udp dpt:sunrpc
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:kshell
ACCEPT     tcp  --  anywhere             backup.skaggscatholiccenter.org  tcp dpt:bacula-fd
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:https
ACCEPT     udp  --  anywhere             anywhere             udp dpt:nfs
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:nfs
ACCEPT     tcp  --  172.17.0.0/16        anywhere             tcp dpt:mysql
REJECT     all  --  anywhere             anywhere             reject-with icmp-port-unreachable
Chain FORWARD (policy ACCEPT)
DOCKER-ISOLATION  all  --  anywhere             anywhere
DOCKER     all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate RELATED,ESTABLISHED
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (1 references)
Chain DOCKER-ISOLATION (1 references)
RETURN     all  --  anywhere             anywhere
Hey,
and
Port 9102 is called bacula-fd, and I guess that the IP 172.16.0.99 belongs to backup.skaggscatholiccenter.org. Which would mean that the rule does actually work. How do you figure that it doesn’t?
Kind regards,
mosu
Because the backup server says cannot see the file damon running on port 9102. It only works with the “all” version of the command which I had enabled right before switching the rules and running the iptables -L command.
Hey,
try looking into what actually happens with tcpdump. Run the following on the machine you want to backup:
tcpdump -n -i any port 9102
Then let Bacula try to connect. What does tcpdump output in that moment? Please also post the output of iptables -L -nv from the machine-to-be-backed-up after that attempt.
m.
this issue was also mentioned on the Barcamp session. I assume @sccmrb also wants the firewall rule in the other direction, so that backup.skaggscatholiccenter.org can connect to 9102. Due to a 9 year old bug, this it not possible: https://forge.univention.org/bugzilla/show_bug.cgi?id=25632
