Firewall Interface select with UCR variable
is there a method to select interfaces with UCR variables to create firewall rules or only with the IP addresses.
I know about /etc/security/packetfilter/50_local.sh but is this the UCS-Way?
Thanks in advance.
according to doc you can use IPs. Not interfaces.
Hey,
As knebb has said, the UCR variables allow IPs and port numbers only. The 50_local.sh is there for exactly this reason: for instances when the bare-bones features of the UCR variables don’t suffice. So yes, using said file for more complex rules is the UCS way.
Kind regards
mosu
