Fingerprint / Biometric sensors
I am wondering if it is possible to authenticate users via fingerprint sensor?
Is there any option avalaible?
Thanks in advance.
depends what user authentication you want to replace with such a sensor. The Windows-client? This should be no issue as most of the Windows-laptops already offer this option.
What you will need is a connection from the sensor through it’s software to the Univention LDAP in any case.
So it should be possible, yes. But out of focus from view of UCS.
/CV
